Results 1 to 11 of 11
dent in my pipe
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    dent in my pipe
    I have an FMF gnarly pipe on my 2-stroke KTM, put a fairly small dent in it a few years ago. Now when I rev the engine the pipe rattles around. It's like a mix between a rattle and a buzz, only after I rev the bike as the rpm's are dropping.
    I'd like to take the dent out, and have heard of people putting air in the pipe and then putting heat to the dent. Question is, what kind of fitting do I need to come up with to put some pressure in this thing? Just looking to know if anyone came up with a trick or an easy way of hooking the compressor to an exhaust. Thanks fuckers.
    Lifer Pittenger5's Avatar
    Austin
    Re: dent in my pipe
    Where in the pipe is the dent? Header/can?
    For the header Ive heard good things about freezing ice in there.
    Zip Tie Alley #505
    Apr 2006
    massachusetts
    Re: dent in my pipe
    Up high on the fat part of the header. I'll give the ice a go, thanks.
    Austin
    Re: dent in my pipe
    Im no expert, better ask someone whos done it, I know theres situations where it doesnt work.
    Zip Tie Alley #505
    KB KB's Avatar
    Manchester NH
    Re: dent in my pipe
    My pipe on my KTM rattles like a bitch. I was the rubber mounts. They were junk. Check em out ya?
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Re: dent in my pipe
    I have a massive gash in my pipe from my last ride at Clough (along with a nasty case of bursitis in my right shoulder.....grrrr). I have heard there are places that repair pipes with dents. Anyone know?
    KB KB's Avatar
    Manchester NH
    Re: dent in my pipe
    I have a massive gash and always forget to call KB to go dirt riding.
    Doosh call me!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer lrrs313's Avatar
    Asheville, NC
    Re: dent in my pipe
    Look in the back of any MX magazine. I think there are a couple places in Mass/Conn area that used to repair pipes. Or, get rubber stoppers in the proper size, drill one one and thread an air chuck, pressurize pipe (probably use a regulator and start 25-30psi at first), heat with torch, watch dent pop out.
    -Brian
    15 S-Works Venge
    Senior Member netra709's Avatar
    Oct 2007
    Re: dent in my pipe
    There is a place in Derry, NH that can remove the dent for you. Look for HT pipe repair on the net. If you want to do it yourself, it can be done. Forget about the ice. I usually heat the area of the dent first, and then add pressure with nitrogen. The gnarlys kind of suck to blow dents out of because of the heavier gauge metal. I have gone as high as 60 psi with the gnarly on my 200. You will need something to block both ends of the pipe. For the inlet I usually use a rubber automotive freeze plug, with the other end I have a 1/4 hvac shraeder fitting with a piece of hose that I can tighten down over the outlet of the pipe. It should be mentioned, while you have psi in the pipe, don't point the freeze plug, or the other end at anything you don't want to kill. When they come out while pressurized, they are going fast. I heat, then add psi. Pressurizing first with compressed air, then heating is pretty dangerous.
    It is easiest to just pay the huy in Derrry to do it, but what fun is that.
    KB KB's Avatar
    Manchester NH
    Re: dent in my pipe
    How big is this dent? Unless the thing is caved in a dent or two aint gonna hurt nothin yo. Just run it.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Apr 2006
    massachusetts
    Re: dent in my pipe
    It's a small dent, but the huge fucking rattle started when I made the small dent, so I thought they might be related. I really don't know if that's it, just figured I'd start there.
  1. Tank dent repair in VT?
    By 802er in forum Bike Maintenance
    Last Post: 03-12-09, 07:04 AM
  2. Tune have a dent
    By Devil1 in forum Dirty Bastards
    Last Post: 04-11-08, 11:35 AM
  3. fucking dent in cage
    Last Post: 07-05-02, 07:27 PM
