Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 301 to 325 of 330
2006 Daytona Track-day Build
  1. #301
    rrrright down by da beach island boyeee's Avatar
    Quincy, MA
    Re: 2006 Daytona Track-day Build
    well if you need some extra ones to play with, I will have some for sale. I think I currently have 1's and 3's (whatever gives 29mm and 31mm offsets) with the matching Scotts damper mounts. Also have the 0's they come with, no damper mount.
    easy 675 motor in a R6 frame.
  3. #303
    Quote Originally Posted by island boyeee View Post
    Need to get one of those damn castle nut sockets already....
    Posse Adjustable Steering Stem Wrench
    Quincy, MA
    tempting... thanks
    tempting... thanks
    I carry mine with me in my track tool box. Damn handy on bikes. If you're at NHMS for the opening round I'll have it with me.
    Quincy, MA
    just ordered one for $32 shipped on fleabay. thanks for pushing me to finally do it! very few tools missing from my collection, this was one of them. Guess I'll ride this weekend with the inserts currently installed.
    +1 carry it all the time
    McMaster-Carr
  8. #308
    Lifer JettaJayGLS's Avatar
    Tahoe City
    So after riding Savas' bike...I had to have a quick shifter. I viewed all my options, or at least what I thought were options. Stand alone Bazzaz and PC quickshifters are a fortune and may require hard-wiring. OEM Triumph units won't work cause my bike is too old.
    I ended up going with Annitori. It is a strain based gauge. The earlier versions received a lot of complaints as it would sometime kill the engine on downshifts. However, in their latest version, they've allowed you to de-activate any direction you want. This means there is no hassle with push vs pull...you can just turn off the direction you don't want to use. It is incredibly easy too. It bluetooth connects to your phone and allows you to turn off/on push or pull, adjust the sensitivity, adjust the kill time, and adjust the RFX (whatever that is) in both directions. They give you recommended settings and then let you adjust. It only took a few rips down the street to have it dialed in. Its a pretty slick looking set-up, I'd say the right amount of cable length, and lots of color options. I was able to store everything in my battery tray since the lithium ion battery I have is tiny. I used all those foam pieces that Shorai gives you to snug it up ever better.
    I was able to test it out at Palmer on Sunday and it worked flawlessly. It was pretty wet out too, and it held up great to the elements. Not even a glitch.
    $260 with a shift-rod.
  9. #309
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    The sound of that bike.
  10. #310
    Tahoe City
    Couldn't agree more. For those of you who have not heard the pleasure of the noise a triple makes...
    https://www.facebook.com/1823786/vid...26091004642836
  11. #311
    I dug through my box of parts and found that I actually have the #2 inserts with damper mounts. So I got my scotts back on with the new settings. Woot! I ride Loudon next and I don't think no damper is a good idea! I can't believe I rode it like that at Thompson with the busted rib. Tank slappers HURT.
    Tahoe City
    I guess I need to start pushing the pace, I have been running without a damper and not having any problems. I may need to grab few laps in your tow at Loudon next week and see what I can do.
    The 7-8 flip was always a tank slapper on the motard...if it wasn't that was a sign I wasn't on the gas nearly hard enough.
    Corner speed was never my strong point. I typically got it done on the brakes and getting back on the gas hard. This is easy to do on a motard for a few reasons: they're light so they stop real well, they have much less power so there is very little fear of 100% cracking open the throttle, and my front end had so much damn rake to it that it would chatter almost instantaneously.
    With a big bike, this has all completely changed, and corner speed is something I'm working on this season. A can't stress enough how much this past Sunday at Palmer helped. It was wet in the morning, had a drying track, and an eventual dry track. Temps were never warm, and there was a stiff, cool breeze that was taking a lot of heat from the pavement. Running street tires (Q3s) in the rain and then a cool track really helped me get a feel for when things start to slip. Dealing with a drying track helped taper into it. This was probably one of the most informative days I've ever had. Never leave a wet track day. Ever. Once it dried out, I felt pretty tight on the bike, the front end did not feel planted and I struggled to lean it over anywhere near as much as Thompson a couple weekends ago. It took me about one more session to realize this was just feedback, not something wrong with me or the bike. By the end of the day I was able to very safely approach this level around the whole track.
    On Track Media LLC | TTD_Palmer_5-8-16
  13. #313
    At Thompson the only issue is if you don't feather the gas over the crest onto the straight. I have had some crazy shit happen there. The 675 motor is perfect for that spot. Literally hold it pinned and loft the front wheel. The downhill run will cause it to automatically come back to earth just past the second bump. When you wimp out and feather it the wheel hits the second bump and it can get pretty harsh. Or the rear can spin while wheelieing...THat can get pretty wild too.
    Tahoe City
    I short shifted that hill just about every lap on my bike. I kept it pinned, but never really had a major wheelie like you're talking about. Again, I think I need to bump up my pace to start needing a dampener.
    To 100% confirm your theory of that 675 being perfect for that spot....the only time I didn't short shift over that hill is when I road Savas's bike, because short shifting the r6 kinda made it fall on its face in that spot. I road a pretty large wheelie on his bike over that. It most definitely felt faster, but it also puckered up the butt hole a bit.
  15. #315
    I shift before the hill for sure. I think a lot of people carry too much speed through the last turn and are not able to get the throttle wide open soon enough. It's a REALLY long straight. It's faster to roll off enough for that last turn, get the bike pointed with a sort of quick turn, and fire out on the gas really hard and early. Otherwise that whole zone after the last turn and before the crest is wasted at really high lean angle trying to get the bike pointed in the right direction to crest the hill.
    Interesting..
    Ooops, I shouldn't reveal all my secrets here. Someone might be listening...
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Even an SV can wheelie through that spot.
  19. #319
    Tahoe City
    The bike is more than capable of wheelieing there. I decided to just be a pansy and prevent it.
  20. #320
    Sep 2010
    Granville, NY
    Same here. I seldom wheelie Fanny over the hill. I respect the hill on that bike. Not so much on the SV...
  21. #321
    Jul 2014
    Central CT
    That was just my poor attempt at saying what you said.
  22. #322
    My sv never lifted even a little bit there.
    Sep 2010
    Granville, NY
    Twist the throttle more
  24. #324
    Or do what I suggested...
    Quincy, MA
    All my research lead me to go with the Annitori as well, whenever I decide to dump more money into this thing.
    I have #3 inserts up for grabs with the Scotts mount, if anyone is looking for a change. I went back to #1 with 5mm of fork showing (Riders Discount setup).
    "wheelie hill" is definitely a make-or-break it spot for a lot of people at Thompson. I used to ride in 3rd, and shit myself with the wheelies/wobbles. Now I short-shift to 4th after the chicane (running -1/+1), and drift wide on the gas, roll off as I climb the hill and point it towards the pit out, so as I come over the hill I'm already standing it up and pinning it. I pass many 1000s here. The ones with extra balls will get back by me by the tower though.
    I do find that I don't like the Scotts damper nearly as much as my GPR... wish they would make an attack mount.
  1. For Sale - Motorcycles | 2006 Daytona 675
    By Trouble in forum For Sale
    Last Post: 06-04-16, 06:43 PM
  2. For Sale - Motorcycles | 2006 SV650 ULSB Race Build
    By MikeBike in forum For Sale
    Last Post: 04-08-16, 05:51 AM
  3. For Sale - Motorcycles | 2006 Triumph Daytona 675
    By veech130 in forum For Sale
    Last Post: 04-18-15, 08:27 AM
  4. FS: 2006 Triumph Daytona 675 Track Bike
    By Palm Bomb in forum For Sale
    Last Post: 07-14-11, 04:58 PM
  5. Triumph 675 Daytona 2006
    By Epee in forum For Sale
    Last Post: 08-06-10, 02:49 PM
