Re: Bad decisions were made today..
Quote:
Originally Posted by
R7
Maybe, just maybe there will be a video of the R7 running in a couple weeks. I’ve been in contact with a guy from the UK that has a lot of Parts, has most of the correct fuel lines, new fuel injectors, and other assorted small parts I need. Still no airbox to throttle body gaskets, but he’s looking through the crates of parts still.
Attachment 61457
My filament dryer came in today so I should be able to get the printer fired up again. Now to figure out how to use this scanner app and print something afterwards.
csmutty
When did you get the R1 LE?!?
I picked it up a couple weeks ago, it’s a sweet ride and in incredibly good condition for it’s age.
1 Attachment(s)
The elusive diamond shaped gaskets, have been found:hbang2:
It’ll be an expensive bill for the parts coming, but should be the last of it.
I’ve got all the pressure fuel lines coming, the 4 diamond airbox gaskets, and a new set of throttle bodies. The throttle bodies I only need the 4 fuel injectors from, but having spare parts is a good thing I guess.
Attachment 61471
Insane. I can't believe you tracked these parts down.
Estimate on what the bike is worth when done? Are they that rare? This like a $20k bike?
xrocket21
way more than that if complete, running, and all OEM like Mark's is.
i think his last one sold for 25k and was immediately flipped
xrocket21
It’s been frustrating at times, but the challenge of finding parts has been satisfying.
The bike as it sits now, is probably worth about $50k. Once complete and running, probably $65-70k.
It’s been quite a few years since an R7 has sold on iconic, but the last one sold for north of $50k, with way more miles/KM’s than mine.
I have no intention of selling it.
i want one of these badly
R7
Oh, oh..... Well, thanks for clarifying
holy fucking shit
I can't believe you sold your first one
LuvDog
I regret selling it, my lifelong best friend regrets not buying it.. lol
I’m thankful for the opportunity to have bought this current bike and restore it.
1 Attachment(s)
Attachment 61518
Let the fun start, question is, will it run?
The remaining chain guard parts are also on their way.
Let's goooooooo!
It's crazy to think how rare that little pile of parts is.
Such a sick bike, and annoying Yamaha brought the nameplate back for a parallel twin :mecry:
R7
Attachment 61518
Where do you even start looking for unicorn blood?
Gixxer
The R7 badge isn’t really a big deal, it’s the OW-02 that really sets it apart from others. The OW-01, was the homologation version of the FZR750/FZR750RR.
obsolete
I’ve found most parts on a FB group. The owner of the group used to be involved with the WSB series with Yamaha. Most of what he has, are YEC race parts for the OW-02… which are even more rare than the standard OW-02 parts, but he does have quite a few new old stock parts.
From the same group, I was able to connect with Sidz Motorcycle Racing from South Africa, the owner has 2 R7’s. I had spares that came with my bike that he needed, he had spares from his bikes that I needed, so we traded parts.
Iconic motorbikes has been a huge help as well. One of their techs had a bunch of R7 parts that I bought.
It’s definitely been a challenging and time consuming effort to find parts.
R7
I have no doubt that you will be able to get it to run.
R7
That adds such a fun history to the bike even though they have enough.
2 Attachment(s)
Spent a little time working on the bike this evening. Replaced the four primary fuel injectors, cleaned the fuel rails, put all the new gaskets and sensors in the airbox, installed the new fuel lines, and cleaned and installed the secondary shower injectors.
No more codes on the dash now that everything is hooked up properly.
I need to clean the inside of the fuel tank, put some fresh fuel in it, and see if it runs.
Attachment 61528
Attachment 61529
R7
Attachment 61528
Attachment 61529
Jesus Christ man. Don't throw on a sexy little number and then fall a sleep! We need this.
seriously 462 KM on it????
obsolete
lol, sorry about that. I tried this evening, while I did get it to start briefly, fuel was starting to leak from the fuel pump gasket. It wasn’t worth the risk of letting it warm up with the fuel leak.
I ordered a new gasket, just need to wait for it to come in.
xrocket21
I’m unsure if it’s accurate or not. I was told it had about 2,000 km on it when I bought it, but wasn’t able to verify for a couple months after I bought it and had a set of keys made.
LuvDog
I haven’t had much luck yet.
It wants to start, I can it to start spraying fuel in the throttle bodies with a hand sprayer, but it won’t start with its own fuel system.
I haven’t a new OE fuel pump, new fuel lines, cleaned the fuel rails, replaced the fuel regulator, replaced the injectors, and still can’t get it to kick. It starts, but instantly stalls.
Any ideas?
R7
Any ideas?
Do you have fuel pressure? Is the pump kicking on with the ignition then shutting off when it reaches needed pressure prime?
PinHead
Yes, it builds and holds fuel pressure. The pump also kicks on and off as it should.
It seems like an injector issue to me, even tho I replaced them with new old stock ones, they are still 25 years old.
Put 9-12vdc power on each one and see if they open.
Are electrical connections in the proper place for each injector?
Chances the wire harness is reversed?
Is the timing set correctly? Cams, flywheel, crank.
Is there an injector pulse signal/pickup/ sensor?
