I ordered a R1 Throttle for my bike. i want to know how to safely take off the grip from my current throttle tube and put it on the new one with out damaging it. and what will i need to do so?
compressed air FTW
.:|LaRNZ|:.
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16)
What latnz said. Use a blow gun to float it off then. I use windex to put them back on.
i have just wrestled mine off in the past but some can be a bitch, i've used grip glue to put them back on, dont want the tube slipping inside the grip once your done
www.bostonmoto.com
Ride to live, live to ride
If you use only air it will not slip. 2 people makes it easier.
If you don't have air then grip glue works great if you wait for it to cure poperly.
Sounds silly, but I used hairspray. That stuff's slippery when wet, sticky as hell when dry. No issues since using that method...
Hyper
alright thanks guys.
but why WD-40? i could understand hairspray, but i have not known WD-40 to get sticky
Might as well put heaters under the grips while you have it apart.
Getting it off, not idea as I alway cut my old ones off. But to install new ones, I use hairspray for the above reasons.
Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
FYI- I used to use hairspray. If you ride in the rain it can get wet and the grip can get slippery.
I don't use anything, but if I'm really concerned, I'll safety wire 'em.
Air only if possible.Originally Posted by Neytiri
Grip glue if there's no air compressor.
I cut mine off then followed progrips instruction using soapy water to put the new ones on. A blast of compressed air to dry them
I've heard a lot about the hairspray method but I'd like to know how they do it at the factory. I've never seen any gripglue remnants when I removed a grip.
Joe
04 Thruxton (Street)
01 SV650 (Track)
Compressed air has given me the best result. Take a blow nozzle, slide it under the inner side of the grip and blow it while working it off. Do the opposite to get it on.
LRRS EX #7
Low Down Racing
Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
Has worked the best for me. Got the tip from Ryan Nicolson on this forum. Grip glue was really messy, and hair spray didn't last.Originally Posted by JonT
The WD40 worked great to slip the grips on, then holds perfectly once it's dry. If you don't believe me, test my street or track bike. Never safety wired any of my grips after trying WD40
so.... then.... should i do the wd-40? or just find some super-glue? i do have the air compressor.
so with the whole moisture thing... does humidity also affect the hairspray>
Little bit of gasoline works great, or brake cleaner.
Allows it to slide right on, just work quick if you use brake cleaner, once it evaporates, that grip is on there.
