Results 51 to 75 of 92
Build of my Turbo Busa
  1. #51
    Chowda!!!
    Coventry, RI
    Re: Build of my Turbo Busa
    Quote Originally Posted by DaveZX6r View Post
    Dude that thing is unreal. You are absolutely nuts. As said before its not something I'd wanna do but that doesn't mean it doesn't make me drool lol. Awesome work so far.
    Lol thanks, V-band came in friday not sure when the fabricators are going to get it done talked to the parts supplier too he rode over there with the wrong pipe again ha. Said he will fix it monday.
    old guy with bikes
    Nov 2009
    Quote Originally Posted by chowda633 View Post
    Love it! Must be a monster though. How do you like the port fueler?
    The port fueler has been good for my application which is a sleeper street bike. I suspect that If I were building all out I would go with a different system, but for a bike whose main job is to lug me back and forth to work and occasionally crush the ego of a squid on his new R1 it is great
    Chowda!!!
    Coventry, RI
    Quote Originally Posted by nhgunnut View Post
    Love it! Yes my application is also starting out as a sleeper setup. Main reason is just not wanting the cut the plastics! With almost a couple of grand paint job we have shyed away at this point as to cutting the plastics for the air filter and exhaust.
    My builder Joey at RPM talked me into going with a GP style exhaust the same as on his turbo 1000 it dumps right behind the rear plastic by the back tire. VERY sleeper. Can't see anything because we are running a FMIC and MOST people think its a big ass radiator and it hides the turbo. Only thing of notice is going to be the SSQ and the 50 trim spooling up but I will be long gone anyways so it should leave them with a wtf was that thing look on there face.
    old guy with bikes
    Nov 2009
    Mine is the Hahn Kit using a Mitsu super 16G turbo I use a low profile K&N FIlter that tucks under the plastic. I am running mid Pipe back to a Micron can. The only mod I have mad to the plastic is on the inside of thr right mid faring because I have relocated my oil filter and I had to cut the inner edge of the scoop. It is not visible from the outside at all.
    Chowda!!!
    Coventry, RI
    Nice! Wow I didn't know Hahn made kits for our bikes they where huge in the DSM world years back great turbo though. Makes great power on the DSM's and a great all around street turbo. Sick setup! Any pics of the bike around?
    old guy with bikes
    Nov 2009
    sure here it is again
    No plastic the day I relocated the fan temp sensor
    Veiw of the plenum and rail
    View of the Brembo raidial master cyclinder conversion
    Chowda!!!
    Coventry, RI
    Very nice! And very sleeper. No issues with heat with no IC?
    old guy with bikes
    Nov 2009
    No the only thing I have done to address heat is to move the fan sensor to the hot side.
    Again the thing to remember is that 7 out of 10 miles ridden are not under boost. If I were using it as a drag bike I would be running an IC but I use this bike as a commuter
    Chowda!!!
    Coventry, RI
    Ahhh true true. Traffic is not an issue either?
    Going to try and heat wrap the exhaust, turbo, and header with DEI exhaust wrap and a turbo blanket. Worked outstanding on my race car going to see if it will make a noticeable difference on the bike 350-400 hp street/race bike still with an FMIC at this point. Only issue with a FMIC is that it blocks a lot of air going to the radiator.
    old guy with bikes
    Nov 2009
    The only time I have ever had a problem with heat was after filling the radiator and not burping it. No not even in traffic. I did take the added measure of a manual switch for the fan so if I do hit stop and go I just turn it on. Some guys add a second fan to their Gen 1s and I may do that just because I like the Idea of extra protection. Lots of the folks I know running stage 1 turbo setups dont even relocate the the temp sensor. Some use the fan sensor from a Honda Accord cause it turns the fan on at 180 instead of 210 the way the Suzuki part does. It is a direct swap.
    Chowda!!!
    Coventry, RI
    Chowda!!!
    Coventry, RI
    Exhaust is done!
    Chowda!!!
    Coventry, RI
    Hmmm good to know! Heat seems always to be the biggest contender in any type of turbo build. Trying combat it the best way we can at this point
    Toyin w/ Student Drivers JonT's Avatar
    Feb 2010
    Southern R.I.
    should sound crazy!
    Chowda!!!
    Coventry, RI
    Quote Originally Posted by JonT View Post
    should sound crazy!
    2 1/2 in exhaust I hope so!
    Chowda!!!
    Coventry, RI
    Welding is all set! Just needs to be wired and the fuel system sorted out and the turbo blanket and exhaust wrap added then we can fire her up!
    Joey's Turbo Busa the owner of RPM
    Lifer obsolete's Avatar
    Norf Sho
    Nice.
    -Alex
  18. #68
    Chowda!!!
    Coventry, RI
    Crew from RPM was at it again this weekend!
    Bike is fully mechanically together now wiring this week into next and we will fire her up!
    Trying something new... Added a lava rock turbo blanket and exhaust wrap to see how much of a difference on cooling we can make.
    Chowda!!!
    Coventry, RI
    New FMIC in!
    Multi Stage in!
    BOV and Intake installed
  20. #70
    When can I ride it?
  21. #71
    Chowda!!!
    Coventry, RI
    When can I ride it?
    When you show me 25k in cash lol. About what I got into it!
    old guy with bikes
    Nov 2009
    I see the fun coming
  23. #73
    Chowda!!!
    Coventry, RI
    IT RUNS!!!! But then battery died hahaha. More pics and videos when the new battery comes in.
    03 Turbo Hayabusa
  24. #74
    Senior Member korndogg's Avatar
    Milton VT
    wow, just found this thread. Awesome build, Chowda. That thing will be ridiculous.
    That FMIC is cool.
    Recognize me from the DSM forums?
    There's a lot of us here!
    Tommy R.
    '06 GSXR 1000
    '03 FZ1
  25. #75
    Can I show it to you in a picture I pulled off the internet?
  1. For Sale - Motorcycles | 07 turbo busa
    By 388 in forum For Sale
    Last Post: 05-11-14, 07:12 AM
  2. Free turbo 'busa
    Last Post: 02-01-12, 09:15 AM
  3. a link for you Turbo Busa fans
    Last Post: 10-17-04, 03:46 PM
