Results 1 to 23 of 23
odd question... harley horsepower
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    question... i am trying to solve a problem for my roomate and his new harley... how many ponies does she make?
    Harley only specs the torque and i cant find a dyno chart anywhere... so all you web surfers with nothing to do... help a brudda out!
    its a 2005 Electra Glide.
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2004
    woonsocket ri
    that pos makes 86 ft pounds of torque @3500rpm
    I did the torque x 5250 \ rpm=hp and got 129hp
    but that number seems high to me. I didn't think hardley made those hp numbers from a stock bike
    Got Boost? katana0215's Avatar
    Feb 2004
    Warwick RI
    im betting its around 75-85 HP.
    The Street Rod and Vrod make around 114 hp
    Oct 2001
    Bedford, MA
    It's more like 50-60hp stock... and that is from looking at Dynos.
    The issue is it makes that huge amount of torque pretty close to idle and immediately tails off... it is not making anything like peak torque at 5000+ rpm where it starts to translate into serious horsepower.
    Senior Member MnM's Avatar
    Apr 2005
    Central MA
    I found that the 2002 model had 67 horses so i don't see it jumping up that much for the 05 model. My gues would be in the 80's range because the 2005 has more cc's
    Oct 2001
    Bedford, MA
    They do make in the ~85hp range with the screaming eagle kits, Stage 1/2 mods, etc.. that most owners do...
    Harley just can't stick that on all the models cause it violates some of the EPA stuff or something.
    Basically they can make plenty of power but not in a clean/efficient manner like a newer design.
    Mar 2004
    woonsocket ri
    this site has some information but i haven't found the exact numbers for the harley
    Lifer GMAN226's Avatar
    Coventry RI
    That is only if the thing will spin 5250 which I don't think it will
    Gerard
    Oct 2001
    Bedford, MA
    EVO Stage 1 - 64hp
    EVO Stage 2 - 74hp
    EVO Stage 3 - 95hp
    EVO Stage 4 - Drop in TL1000, RC-51, Duc engine
    Mar 2002
    Amherst, NH
    what the hell does evo mean in those stage notations?
    60 hp doesn't seem right? seems to low to me. its a 88ci with the fuel injection... my ass dyno was guessing mid 70's.
    Brent LRRS #772
    2006 KTM 560 SMR
    Oct 2001
    Bedford, MA
    I think it just means "Evolution engine" That is the name for Harley's latest Big twin air-cooled motor AFAIK, the motor that basically saved the company.
    Unless they changed the name again the last few years.
    Cruisers always feel faster than they are... the butt-dyno does not work correctly between a sportbike & cruiser IMO.
    granite state
    i don't care how many times they redo that air cooled dino motor its still old technology. the more power you try to make with them the less reliable they become.
    ben said it right drop in a rc51 motor. talk about a sleeper!
    that's cause I think you multiply the torque by the rpm then divide by 5250, that would make it 57.3 @ 3500 prolly 60something at a 4000rpm redline
    Member lee955i's Avatar
    Sep 2002
    Winter Haven, FL.
    The "EVO" does designate the evolution engine but they don't use that in most of their newer bikes. They now use the TC88 motor which stands for "Twin Cam" and does put out about 10-15% more hp than the Evo. Not to be confused with the "Revolution" water cooled engine used in the V-Rod.
    Cheers, Lee S.
    I know i'm slow, you don't have to rub it in.
    Why, Yes! I do think you're a Wanker!
    Mar 2002
    Amherst, NH
    ah HA! So that means the TC88 might put out about 70 hp?
    sweet! My Arse dyno IS IN DEED tuned, thank you very much!
    thanks for all the info, i knew you guys wouldn't let me down!
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2004
    woonsocket ri
    You know that looks about right. The way I did it is straight from a web site which may have it wrong. I thought the harley made around 60hp
    It's really funny how harley will not put out their hp numbers, maybe because a 1340cc motor ought to make more hp by accident thanit actually does.
    rc51 pilot damannz's Avatar
    w. mass
    those things only redline at 4k?lmaoo
    Northshore/Beverly, MA
    They will go to 5500...Reason for such low HP, is because they have to keep the compression ratio low to pass emissions.
    Re: odd question... harley horsepower
    I recall having seen hardley dynographs, I don't remember any numbers, peak 86lbft is misleading , they have a flat torque curve, wouldn't surprise if it's 75 or more at an idle, then it drops off as it approaches redline.
    ya, that means whomp ass stump pullin power
    Mar 2004
    woonsocket ri
    Re: Re: odd question... harley horsepower
    If you check the websites they all say 86 ft pounds but you know it's bhp not rwhp
    you forgot to divde by two
    if it is a Twin cam motor (which im sure it is) then this math will almost be correct. 75 HP out of a stock TC is about normal. Evo's put out around 60-65.
    none of this matters because my SV makes more power than both
    also i beleive the number is 5252 not 5250 since 5252 is RPM that HP and Torque are exactly the same...on every bike
    not that it makes any difference in the math
  1. For Sale - Other | Murray Snowblower - 24" - 8 Horsepower
    Last Post: 12-07-20, 07:40 AM
  2. What to do with an old Harley?
    By bryco13 in forum General Bike Related
    Last Post: 11-21-10, 01:45 PM
  3. no horsepower in Iraq
    By Nix in forum General Bike Related
    Last Post: 04-12-10, 02:31 PM
  4. Is it a Harley?
    Last Post: 12-04-04, 12:18 PM
