Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Clutchless Shifting
    Southern, NH
    Thumbs up Clutchless Shifting
    So, I experimented this weekend and it's crazy how much smoother it is shifting without the clutch. A little preload on the clutch, let off the throttle and BAM up a gear!
    Everything I have read says that it's actually better and puts less stress on the engine.
    Dec 2003
    Ma
    Clutchless Shifting
    Try it with using the rev limiter instead of letting of the throttle. Now THAT is smooth.
    Clutchless Shifting
    your good, I've never been able to get it to shift without using the shifter
    all I can really say is if your shifting is smoother without the clutch, you should be practicing your clutched shifting rather than your clutchless shifting
    clutchless shifting is only smoother than hamfisted clutch use
    Southern, NH
    Clutchless Shifting
    I have to correct my original statement. I meant preloading on the gear with about 3 lbs of pressure.
    I am not using that as my main means of shifting, i just thought it was cool and could be useful when doing higher speeds.
    Clutchless Shifting
    I agree it can be smooth when not using the clutch. I was always under the impression that clutchless shifting is hard on the shift forks. I am sure there is going to be a pros and cons list a mile long on this as there are supporters of both methods. 99% of the time I use the clutch; when I am pushing it hard I will not use it on 3-4-5-6 shifts but always on the 1-2 shift.
    Anyone know the truth on long term shift fork damage due to this style of shifting?
    Now that I think about it as my riding style has evolved I notice I am really just taking a light jab at the clutch when shifting instead of a full pull and release. Who knows maybe I have myself in bad habits now...........
    2001 Yami
    2005 CBR - Retired
    Southern, NH
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Clutchless Shifting
    Under full accelleration, shifting without the clutch is much quicker, and better all around for your components. Under lazy accelleration, the clutch is your best bet. (remember every time those clutch plates come apart, and then come together, your going to get clutch bits in your oil (unless your riding a dry-clutch). I would think the obvious fact is, the less clutch bits in your oil, the better everything is.
    Apr 2006
    Beverly, MA
    Clutchless Shifting
    I recently started practicing this as well. The only time I really find it smoother than with a clutch is when you're going WOT. Using the clutch at WOT makes me feel as if I'm not holding onto the bike as best I can. Other than that clutch shifting (up or down) is far smoother IMHO.
    As the OP said though, it is REALLY smooth at WOT. It literally just clicks right in when you get it right. And putting a littler preload on the shift lever really helps to make it go in smoothly.
    So, WOT + clutchless shifting = win!
    KB KB's Avatar
    Manchester NH
    Clutchless Shifting
    Welcome to 2007 Bill.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Southern, NH
    Clutchless Shifting
    Quote Originally Posted by rmbbikes View Post
    Thank you! It's good to be here. I am really enjoying the use of electronic mail (email for short) and the use of high octane petrol.
    The 90's was overrated
    Clutchless Shifting
    i do it if im riding one handed and i also do it to downshift....TRY THAT!!
    Jun 2005
    Heres my 2cents
    [QUOTE=RPloaded;357609]I agree it can be smooth when not using the clutch. I was always under the impression that clutchless shifting is hard on the shift forks. I am sure there is going to be a pros and cons list a mile long on this as there are supporters of both methods. 99% of the time I use the clutch; when I am pushing it hard I will not use it on 3-4-5-6 shifts but always on the 1-2 shift.
    IF You do it right, it wont hurt anything. When u cut the throttle slightly between shifts, it takes the load off the transmission, letting u pop right up into the next gear. IF YOU Miss Gears / force & grindem in, eventually your gonna have problems. I know a guy who owns/runs (JP) a racebike/bike shop, who has 30 or 40 years of experience with this topic. He doesnt even use the clutch anymore except for getting outta first gear.
    Clutchless, feels kinda like havin an automatic or a beefed up car with a shift kit. .. SINCE im a pussy about hurting my bike,,,, I do a clutchfree run once in a blue moon because im paranoid. I can shift just as quick with the clutch, the only advantage to this technique im guessing is at the track,enableing u to focus on stearing, not squeezing the left hand ( ehehhehe some call it the Stranger ehh heheh).. That is all
    KB KB's Avatar
    Manchester NH
    Clutchless Shifting
    Yeah there yah go take some advice from Firefag!!! Afterall he knows a guy that nows a guy from JP a racebike shop with 30 or 40 (not sure) years of experience. Stearing is afterall more important than using the clutch!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    Clutchless Shifting
    +1
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Clutchless Shifting
    IDIOTS
    Please list your names so i never buy a bike from you
    Do I do this; yes sometimes under extreme circumstances and like up hill on a dirtbike.
    It ain't good for anything
    Glen Beck is John the Baptist
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Clutchless Shifting
    I just installed the dynojet shifter last night... clutchless and harmless.
    Jun 2005
    HaFriggin Ha ehehehehe Ass
    His name is JP ya jackass.And its in NY. I could write a long rebuttle , but your just gonna flame me anyway. Fuggin Moose Nuckle.
    If your leaning it over in a right turn, u want to keep ur left arm relaxed along the tank while still gripping the left clipon. The Reasoning is This: You want to contol your turn with your right arm by pushing and pulling. THe idea being that you dont want your arms fighting each other for control through the turn ( smoothness) Using the clutch forces u to use muscles in your left arm, although its brief, not having a sure grip with ur left hand at the wrong split second when u need it there, could mean the difference between crashing or recovery.
    Clutchless Shifting
    Quote Originally Posted by richw View Post
    IDIOTS
    Hey Rich.... do you also believe masturbating makes you blind?
    Speaking of which, clutchless shifting is like masturbating... absolutely nothing wrong w/ doing it, feels good, ya still get off & if ya know what you're doing it can be even better than the alternative.
    Littering and........
    Jul 2004
    Vermont
    Clutchless Shifting
    Quote Originally Posted by FireFly View Post
    Its "rebuttal", not "rebuttle".
    Did you figure out if your clutch was burned out yet? You should go think about it some more.
    Jun 2005
    Lol
    Dude its all good. ur not getting me to open my bike up again. Its friggin fine. Rich, people could only hope to buy a used sportbike from someone like myself. pete can attest to how OCD i am about taking care of my machine, mechanically and comsmeticly. YEAH DAWWWWWWGGGGGG!!!!!!!!!!
    Clutchless Shifting
    I'm with Rebelpacket...
    When shifting "lazy", like much of my street riding, I'll use clutch up and down.
    On the track, when each upshift is happening at top of RPM range, I do not use it. I do not believe it causes any more harm than a clutch shift in these conditions. And I know that it helps you ride smoother, faster, and with less fatigue.
    I also know some people will downshift without the clutch, but I don't recommend that (even though some of my instructors do it)
    I think there is much more chance for damage to the tranny, and damage to your body, when downshifting without the clutch.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Clutchless Shifting
    Quote Originally Posted by 35racer View Post
    +1.
    Regarding clutchless downshifting, i've said it before & i'll say it again. I do it on a regular basis but I don't recommend it. I found myself having to re-encorporate the use of the clutch for downshifting back into my repertoire in places such as turn 11 where I'm leaned over, trail braking and downshifting. Do it wrong there & you can find yourself in NASCAR 4.
    Aug 2004
    Baltic,CT
    Clutchless Shifting
    Rounded dogs
    Jun 2005
    yes and No
    Rounded Dogs, Only if you Do it wrong. its all about keeping the main shaft and the countershaft in sync. Rounded dogs can also happen from halfassed shifts ex. when u slipp out of gear and hit a false neutral. Bad shifting with the clutch can be equallly damaging to a bike tranny. Preloading for clutchless upshifts etc.. will have negative consequences over time. There is No need to preload the shift lever. Your putting unneeded stress on the shift forks, over time this will lead to constantly popping out of gear and needed tranny repairs...
    Clutchless Shifting
    Agreed.
    I never preload.
    I don't want my foot touching the shifter... unless I'm shifting.
    Tony
  1. involuntary clutchless downshifting practice
    By brady in forum General Bike Related
    Last Post: 08-31-15, 12:21 PM
  2. clutchless DOWNshifting
    Last Post: 06-03-15, 06:36 PM
  3. Clutchless shifting..
    By bump909 in forum Bike Maintenance
    Last Post: 07-03-05, 12:15 PM
  4. CLUTCHLESS UP SHIFTING is ok for your trany
    Last Post: 07-21-04, 09:14 AM
  5. clutchless upshift
    Last Post: 01-07-03, 04:37 PM
