Page 23 of 30 FirstFirst ... 3131415161718192021222324252627282930 LastLast
Results 551 to 575 of 742
Count Down Untill 2013 Season Kicks Off!
  1. #551
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Re: Count Down Untill 2013 Season Kicks Off!
    Swapped as many parts as possible to the new frame and buttoned up the right side of the case. I somehow destroyed the main seal on the left side while putting on the primary drive so that won't get done until next weekend. I brought the top end with me to my apartment for further inspection. I most likely will be keeping the head as is. If the valve seats don't look as good as they should I probably will lap in the current valves and deal with it after the race weekend. Need to order piston today along with a few other parts. The cylinder looks spotless but im debating whether or not I should just order a new one since they're so cheap and I've replaced everything else at this point...
    And my trailer surprisingly looks great!
    Overall a decently productive Sunday.
  2. #552
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    Cheap Cylinder? Where ?
    Quote Originally Posted by lrrs428 View Post
    They are very cheap brand new. I got mine for sub $200.
    Tahoe City
    http://www.ronniesmailorder.com/fich...02&fveh=132343
    $240.
    I guess "cheap" is all relative, but when you look at what I've spent so far, it isn't a huge amount. Plus, I have a very good deal worked out with my local shop so I bet It'll be right around the $200 mark.
    I mean, the thing looks absolutely spotless, part of me says just run what I got, part of me says replace it since I've done everything else.
    In the process of writing this post I just talked to the guy at my honda shop and he said just piston and rings and call it done...
  5. #555
    #331 CBR929RE's Avatar
    Bridgewater, MA
    clean/condition your gear.
    Find someone with a good boregauge and have them check your cylinder. If it's in spec, run it. You'll want to have your piston on hand for this.
    On my front, life is doing it's damnedest to keep me from the track. I did manage to redo the fuel plumbing to how I want it, air filter frame is in place, carbs are tightened down so that area of work is done. Suspension is back from Mr Kates with proper springs so that has to get put back on, then mount the bodywork and test the fuel system and the bike will be good to go. (I should set my sag too but that'll likely get done at the track if I can find some help.) Goal now is to get everything but the bodywork done so I can wheel it out of the basement this weekend.
    Lifer Trouble's Avatar
    Monkton, VT
    Yup. Washed my leathers this weekend. Hopefully they'll be dry before next weekend...
    The SV is good to go. All that's left for the Hawk is to add fuel and fire it up (fingers crossed). Oh, and take some photos of the repaint before it gets "scuffed" again...
    The trailer needs a couple hours of attention but then I'm good to go!
    LRRS EX #7
    Low Down Racing
  8. #558
    Quote Originally Posted by Trouble View Post
    how do you wash your leathers?
    Monkton, VT
    I used Todd's method.
    http://www.nestreetriders.com/forum/...rs#post1268729
    LRRS EX #7
    Low Down Racing
  10. #560
    i guess that will be one more new thing for me to try this year lol
    Bridgewater, MA
    if they don't stink then you don't have to rush to do this before the season. I just scrubbed the outside of mine to get the grime off. and I always put the suit on the hangair when I'm not wearing it at the track. and I never stuff them in a gear bag. mine have never stunk.
    Tahoe City
    My method as well. And I sweat like a behemouth.
    Although I sorta regret buying white leathers...they're super tar stained/scuffed.
  13. #563
    Senior Member WinVT's Avatar
    Winooski VT
    can't remember, is engine ice lrrs legal?
    LRRS #313
  14. #564
    ya they dont smell bad at all. i figured id just clean them. what do you use to clean on the outside?
    Quote Originally Posted by WinVT View Post
    Just run water and some water wetter. Much cheaper.
    Rulebook says:
    19.10 Liquid cooled engines and their radiators must be
    flushed. Only water or an approved cooling system
    additive may be used. The use of anti-freeze is subject to a
    $50 fine. A list of approved additives is available at Tech.
    Inspection.
    Winooski VT
    Rulebook says:
    Inspection.
    Yeah I read that, just didn't know if engine ice was a tech approved additive. I just have engine ice with me now and i'm too lazy to go across the street to get distilled water.....
    LRRS #313
  17. #567
    When they said additive I think water wetter. Engine ice really isn't an additive. It is a whole replacement for the fluid. That's how i interpret it anyways.
    Tahoe City
    And you really don't want to be the guy that delayed racing an hour because you spilled coolant all over the track.
  19. #569
    Engine Ice is NOT LRRS legal. Water Wetter and Maxima Cool-Aide are LRRS approved.
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    I'm quite sure it's legal, just can't remember where I read it. I've been using it for a season now.
    LRRS 878 Clapped out Gixxah
  21. #571
    Quote Originally Posted by wiggeywackyo View Post
    I can assure you, Engine Ice is NOT LRRS legal, I just went through verifying this myself. Engine Ice is just a glorified standard antifreeze, aka slippery as all hell, hence why LRRS doesn't allow it. CCS allows it as they are a main sponsor, so if you want to attend other CCS races feel free to run it, just not at LRRS events.
    Feb 2009
    City
    Thanks for clarifying. Maybe the CCS bit is where I got that from.
  23. #573
    Winooski VT
    Water wetter it is! Thanks.
    LRRS #313
  24. #574
    alright i guess thats another thing I have to do Thursday night lol
    If you want to go maximum lazy, Maxima Cool-Aide is also available in pre-mixed form rather than as a concentrate. No measuring, etc, just pour and go.
  1. 94 DAYS UNTILL 2015 LRRS RACE SEASON!!!!!
    By lrrs428 in forum Pit Area
    Last Post: 05-14-15, 05:10 AM
  2. 100 DAYS UNTILL 2014 RACE SEASON
    By lrrs428 in forum General Bike Related
    Last Post: 10-06-14, 10:27 PM
  3. 2013 SX season - maybe best ever
    By backinthesaddle in forum Dirty Bastards
    Last Post: 03-25-13, 08:31 AM
  4. Count Down Untill 2012 Season!
    Last Post: 04-28-12, 07:19 AM
  5. Count Down Till' 2011 Race Season
    Last Post: 04-16-11, 11:43 AM
