Results 1 to 8 of 8
Draining coolant before freeze
    Windham NH
    I switched my coolant to water/water wetter before my last track day. My bike will be in an unheated garage over the winter. Do I need to switch it back to antifreeze/water or can I just drain it? Will it drain completely if I pull the coolant drain plug and overflow reservoir hose, or do I need to do anything else to drain it completely?
    Extra piece of info- I dont have a key at the moment, cant start the bike. Probably wont look into getting another one for a few weeks.
    Jun 2005
    Re: Draining coolant before freeze
    I'd prefer to have anti-freeze in it myself so that there's no chance of freezing, so that the seals are lubricated and so that it's not just open to the air...
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    I'd recommend replacing the water with antifreeze. Generally not great to leave the system open. Stuff can tend to dry out.
    I'd also recommend starting it and running it for a few minutes to get the antifreeze circulated and "mixed" well with any pockets of water than might be trapped in there, but that's probably not an option.
    Can you pick it up and shake it?
    KB KB's Avatar
    Manchester NH
    I'd also recommend starting it and running it for a few minutes to get the antifreeze circulated and "mixed" well with any pockets of water than might be trapped in their, but that's probably not an option.
    You could always get a couple guys to lift it!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    I pick mine up and tip it upside down to get all the water out..........
    #331 CBR929RE's Avatar
    Bridgewater, MA
    fill with antifreeze. tip bike over all the way you can. squeeze hoses. when you finally get a key run it up to temp, at least until the thermostat opens. I usually just run it all the way up over 200°. I like to get all the air bubbles out.
    I was advised to run the bike until the t-stat kicked over. Not knowing what temp this would be at, I was advised to leave the radiator cap off. This was a bit messy, but worked.
    I put 50/50 mix in, not straight antifreeze. It was the non-silica "aluminum safe" stuff that folks were recommending in another thread.
    I also drained and replaced the engine oil with fresh. And topped off the gas tank with stabilized fuel. Tires are slightly over-inflated and she's up on the race stands off the floor. Oh, and the battery tender is plugged in.
    Plan to swap the coolant in the street bike before long too.
    Lifer Stromper's Avatar
    Eastern Ct
    It will freeze expand and you will not be happy
    You will have to circulate
    Or cover with blankets to the floor put a 40 watt light bulb under the motor
    The calculus of hate
  1. Non-Glycol Freeze Protecting Coolant?
    Last Post: 10-04-19, 04:40 PM
  2. Draining front brake fluid
    By Garandman in forum Bike Maintenance
    Last Post: 04-29-19, 11:03 AM
  3. Draining coolant reservoir
    Last Post: 10-21-08, 12:28 PM
  4. Draining Water...
    By Stoneman in forum Pit Area
    Last Post: 11-10-03, 06:19 PM
  5. why is anti-freeze
    Last Post: 11-19-02, 07:34 PM
