Results 1 to 10 of 10
Electrical Rigging - GPS
    In hibernation
    Manchester, NH
    Anyone rig a usb-DC (lighter adapter) GPS cable to their bike fuse box? (specifically GSXR). What did you need? How 'messy' was the install?
    Lifer Wishbone's Avatar
    Jul 2006
    Re: Electrical Rigging - GPS
    I have a 12v outlet on my bike. I just used a relay from the main power (fused) and switched it off of the first switched circuit I could find. Looks nice because I had room to put it up in the front fairing along with my heated grip switch.
    In hibernation
    Manchester, NH
    Quote Originally Posted by Wishbone View Post
    Hmmmmm..... might have to bribe you with lots of beer to help hook a shock-prone brother up LOL
    Apr 2006
    Beverly, MA
    I've wired GPS both ways. I installed a cig lighter in the trunk of my old SV (using a relay), but I found using the hard wire kit looked a lot cleaner. If you're ever in the area I could give you a hand. It's really easy. PS I just followed you on Twitter.
    In hibernation
    Manchester, NH
    Thanks man... might take you up on that, last time i tried playing with power, I accidently kicked on my house's 10,000watt backup generator for 24 hours (that was a high propane bill!)... It's only a matter of time till a lighning bolt sizzles whats left of my brain!
    For an IT guy, I'm f'ing USELESS when it comes to juice LOL
    Quote Originally Posted by schleppy View Post
    Jul 2006
    I never mind helping people out.
    Jul 2006
    Hollis, NH
    Quote Originally Posted by FlynGSXR1k View Post
    1. USB is +5V so make sure you include the lighter adapter's regulator in your installation.
    2. A delicate Mini-USB connection is not going to last very long on a motorcycle.
    Lifer markbvt's Avatar
    Georgia, VT
    I'd recommend installing a Powerlet socket (BMW/Triumph/etc style accessory power socket) -- it's much more compact than a cigarette lighter socket, plus it's weatherproof even when you have something plugged into it.
    Eastern Beaver makes really kickass wiring kits for installing these things. They come with everything you need. All you have to do is figure out where you want to install the power socket on your bike and drill a hole for it.
    http://www.easternbeaver.com/Main/El.../powerlet.html
    I've used Eastern Beaver kits to install power sockets on my V-Strom and my Honda XR650L, and also to install heated grips on the XR. Super high quality components -- I can't recommend this stuff strongly enough.
    Once you have the Powerlet socket on your bike, you can use a Powerlet MiniUSB power cable for completely weatherproof power for the GPS.
    --mark
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    +1
    Jim @ Eastern Beaver makes a good product. I got a wiring harness for my headlights on the bandit because the stock wiring was too small and it has worked perfectly since.
    Majer:Danjer™ ChicknStripEatr's Avatar
    Sep 2005
    RI/NH
    I installed a cig lighter socket ($4.99 auto zone) in the trunk. Fused, tapped it off the fuse block. Works great for the phone charger and the GPS. Though I rarely use the GPS, I find you stumble across amazing roads when you are "lost".
  1. Electrical Help: KTM
    By iTGbuDeeV in forum Dirty Bastards
    Last Post: 05-22-18, 07:24 PM
  2. Any electrical advice?
    By Spooler in forum Bike Maintenance
    Last Post: 09-30-17, 06:36 PM
  3. Rigging headlights on track plastics?
    By Femmekat in forum General Bike Related
    Last Post: 10-17-10, 03:41 PM
  4. Need electrical help!
    By akira700 in forum Bike Maintenance
    Last Post: 04-09-09, 02:50 PM
