Results 1 to 7 of 7
Fabricators - Custom brake bracket
    If I can supply the critical dimensions, anyone up for whittling me out a brake caliper adapter bracket?
    My 92 WR is one of the 4 years that Yamaha used an oddball two piston front caliper, an older design Nissin. Earlier and later bikes use the same unit as Honda's MX lineup. My caliper has seen far better days, so I figured I'd do the Honda upgrade all the other YZ/WR guys do, Honda caliper on a YZ bracket, Honda master and line.
    Well... I can't swap brackets because my caliper uses a different pad retention system. Unlike later Yams my forks DO use the same bolt spacing as the Honda bracket. Unfortunately they don't match the placement relative to the fork. The upper mount is spot on, the lower mount is a good 30mm inwards. To use the caliper and bracket, I need to move that lower mount out.
    I'm thinking a simple steel 'Z' shaped piece will do the trick. One side drilled and tapped to accept the standard mount point/bolt, the other side drilled but not tapped, a new short bolt through it into the caliper bracket and I'm golden.
    Hell, it can be a single lump of steel with a notch milled out to go over both ends of the stock mount so it's double hung, and then a light notch on the wheel facing end to set the depth for the second hole.
    In the mean time I'm going to resume attempting to coax the pad pins free on my old caliper so I can tear it down and clean it, it drags too much for my taste. That plus the new line and master should improve it's performance but I'd still like to chase using a newer caliper if I can.
    May 2011
    Holyoke, MA
    Re: Fabricators - Custom brake bracket
    http://www.emachineshop.com/
    You can download their software build your part to spec and have them whip you up one. It's not cheap though. At least for one off pieces..
    May 2011
    Holyoke, MA
    if you make something like this out of 7075 aluminum to make up the difference in that bracket connection it'll cost 400$ from emachine shop for a one off part.
    Yeah, which is why I'd prefer something other than them for a one off. eMachineshop is fun to play with but man that is some expensive prototyping. I'm really curious how many people actually use their service, and what they are making for parts.
    Plan B it is then, find a piece of steel and have at it with a grinder...
    Lifer eboos's Avatar
    Kurlon, if you are looking to make something like the above picture, send me the dimentions, and the material and I'll hook you up. A piece like that would be amazingly easy, and I can crank it out in no time. No charge.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Quote Originally Posted by Tunertype View Post
    BUZZKILL
    Quote Originally Posted by eboos View Post
    WIN!
    Much appreciated, at the moment I'm being foolish and trying to revive the old caliper first, going to abuse a friend's ultrasonic cleaner. If that doesn't work I've got the two critical numbers and will sling you a note. Thanks!
  1. Wanted - Parts & Tools | wtb brake reservoir bracket
    By tsorfas in forum Wanted
    Last Post: 05-11-16, 08:28 AM
  2. Custom brake lines for dirty bikes
    By Kurlon in forum Pit Area
    Last Post: 04-07-15, 07:33 AM
  3. 2001 CBR 929RR Single Sided Swingarm, custom custom custom
    By customfighterer in forum For Sale
    Last Post: 06-29-10, 02:03 PM
  4. WTB Brake Reservoir and Perch/Bracket
    By jcbell1007 in forum For Sale
    Last Post: 03-24-10, 06:05 PM
  5. custom brake reservoir covers
    By bryco13 in forum Business & Product Reviews
    Last Post: 01-04-09, 10:33 PM
