Results 1 to 24 of 24
flat black helmet
    BAMF dingley00's Avatar
    Lincoln, RI
    flat black helmet
    hi,
    i love all black helmets, but i've only had gloss black helmets. how do flat black helmets look? opinions? how do they hold up to scuffing? i'm thinking of getting the GMAX GM68S in flat black, but they also have a cool dark silver gloss... which one would you suggest. this will be a passenger/spare helmet... so dont' tell me to go buy an arai/suomy/shark/shoei/etc.
    2010 Kawasaki Z1000
    LRRS Rider #256 QuarterGig's Avatar
    Gorham Maine
    Re: flat black helmet
    my icon held up ok for 2 years. my HJC wore off to shiny black on the chin in 1 season i was very dissapointed.
    so depending on how they put on the finish it may be great clean up well or it may be crap and just come off on it's own.
    Seth
    LRRS/CCS NV #256
    2007 Ducati S2R1000 Street
    2000 Triumph TT600 Track For Sale
    1984 Honda Magna needing reassembly.
    1974 Honda CB 750 needs wiring
    1974 Honda CB 350 needs engine work
    I would pick the Flat Black Icon over the GMax for sure but its your life and if you think buying a cheap helmet is cool and not worth spending money on, then this post really isn't worth shit cause ur a DUMMY and needs to be deleted...
    but be smart and buy an ARAI YA chep prick...just my 2cents
    Lincoln, RI
    Quote Originally Posted by Dingley00
    maybe someday you'll learn to read...
    2010 Kawasaki Z1000
    Member NinjaMegz's Avatar
    Jul 2008
    Western Mass
    I have the flat black Barbwire Helmet by HJC...it's nice
    NINJAMEGZ AKA NINJALEGZZZ
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    passengers have the right to have their heads protected from getting splattered all over the pavement, too, you know...
    hurray, strikethrough!
    Lincoln, RI
    does the DOT not have good standards?
    2010 Kawasaki Z1000
    Apr 2006
    Beverly, MA
    My flat gray HJC held up fine for almost three years. Just make sure you stay on top of cleaning it off if you get a lot of bugs/fingerprints on it.
    Member flintoid's Avatar
    Apr 2008
    Brighton, MA
    Quote Originally Posted by dingley00 View Post
    helmet opinions are very broad. People also swear by certain brands because they've been down in different ones. Whether they get a face full of dirt in a certain turn or not up in Louden can create good or bad impressions.
    As far as flat black helmets go, I've got an icon mainframe flat black helmet. It's had 2 years put on it and it's held up 'ok.' It scuffs fairly easy, but helmets scratch just as easy, too. It tends to retain grease from oily hands, too, but it is cleanable.
    If I were to get another flat black helmet, I'd go with an icon airframe flat black. I have an airframe (the eternal sinner version) and I"d have to say it's one of the nicest lids I've ever worn. Stable, light, and fabulous venting. I love it.
    Gorham Maine
    i have lampshades that will pass DOT.. make sure it is SNELL
    Seth
    LRRS/CCS NV #256
    Lincoln, RI
    Quote Originally Posted by QuarterGig View Post
    i checked out the website. especially this page. Snell/DOT Comparison
    obviously it's a biased article since it's from the snell website. however, there doens't seem to be too much difference between the two criteria. the snell test is done from a higher height 3.06 and 2.3 m vs. the DOT's 1.38m fall. 150J/110J is the impact severity standard, while the DOT has less than half that in some cases...
    what is the real life application of Snell's 150J/110J vs. DOT's 110J/110J?
    Last edited by dingley00; 07-14-08 at 01:44 PM. Reason: understanding something after posting, i'm an idiot :)
    2010 Kawasaki Z1000
    Apr 2008
    Brighton, MA
    obviously it's a biased article since it's from the snell website. however, there doens't seem to be too much difference between the two criteria. the snell test is done from a higher height 3.06 and 2.3 m vs. the DOT's 1.38m fall. 150J/110J is the impact severity standard, while the DOT has less than half that in some cases... but, it mentions in the 5th paragraph of the article that "The amount of energy is dependent upon the speed or velocity of the head at the moment of impact and it's mass or weight. In helmet testing, the higher the fall or the heavier the headform, the more severe the impact." So obviously, they could have a higher impact standard since they are dropping from a higher height. the weights are about the same, depending on which size your comparing to (the DOT uses more weight for size L but less for size S).
    maybe i'm misinterpreting this?? if i am, please correct me.
    also... what is the real life application of Snell's 150J/110J vs. DOT's 110J/110J?
    SNELL has more strict penetration standards ie: sharp things going through the outer shell of your lid.
    Gorham Maine
    really i am exagerating.
    i will only wear a SNELL for 3 primary reasons.
    DOT looks primarly at flat inpact SNELL looks at hitting corners and edges as well (like curbs)
    To be SNELL it must also be DOT.
    SNELL is required for racing.
    Seth
    LRRS/CCS NV #256
    Jul 2008
    Waitsfield, Vermont
    The Motorcyclist Online article on helmet testing (where they did their own testing) suggests that the Snell standards are suboptimal, and some of the cheaper helmets outperformed the more expensive helmets in brain protection (with better performance defined as the transmission of lower force to the brain). In short, the Snell testing requires helmets to meet a particular threshold, and a lot of people think that the threshold is too high, thus causing helmets to be designed to hold up in an impact that is probably going to be fatal anyhow (due to internal organ damage, etc) while not protecting as well as they could in more common, lower-impact scenarios.
    The whole article is Motorcycle Helmet Design, Helmet Standards and Head Protection - Gear Box - Motorcyclist Online.
    The one reason I would be reluctant to wear a DOT-only helmet is that DOT testing is virtually non-existent. The DOT requires helmet manufacturers to certify their own helmets and only does occasional spot testing of products in the marketplace; I don't like to trust the manufacturers to police themselves.
    Lifer Jayspeed's Avatar
    Medford, MA.
    about the passenger. If they want a better helmet, let them pay up! But if you care for them, maybe get an arai/suomy/shark/shoei/etc.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Andover
    Scorpion Exo 700 in flat black, about 200.00
    Lifer mrezra's Avatar
    Rotorua, New Zealand
    +1 on the Scorpion. Great helmet for the money. I've got the gloss version, my wife has the flat black (I think hers looks better).
    Yeh I've heard those gmax helmets are juh juh juh JUNK but the exo700's a pretty good budget lid in a world of crappy budget lids.
    Personally, I tell my passengers buy their own damn lids. But if the occation arrises that I want to put a friend on the bike that isn't willing to buy their own lid, I've got a couple of extra helmets that i've bought for MYSELF as back-ups or what have you.
    How bout you just buy yourself a new quality lid to mix it up a bit?
    Member Phate's Avatar
    Nov 2005
    NJ
    Ok I'm not getting in the "what kind of..." debate but I will tell you I have two flat blacks and they both look good and have stood up for some abuse. I definitely second the washing and care after riding though because they do tend to show the bugs like a demon. I have one of each of the below although without the chrome look on the HJC.
    Just Registered Brian675's Avatar
    NH
    Buy what you want but snell is a great rating.
    And imo flat black.
    Apr 2008
    Boston, MA
    I like ECE 22.05 certification better.
    Sep 2007
    Hinsdale, nh
    Don't like your passanger
    granite state
    Quote Originally Posted by ultraTwist View Post
    thats what i have. still in good shape after 4 years. rarely used now.... they do scuff easier, just the nature of that paint.
    May 2007
    Southern NH
    ...the semi quarterly religious discussion resurrected...
    I am always amused by these 'style' questions. And even though this was 'couched' as a durability question form wins over function in 97.33% of these cases! (I can provide the statistical analysis of that statement if anyone cares...)
    Muhammad Ali.
  1. Replies: 0
    Last Post: 05-14-12, 01:38 PM
  2. 05 GSXR 1000 Black on Flat paint FOR SALE***
    By Pigman in forum For Sale
    Last Post: 02-15-12, 05:09 PM
  3. Black/yellow jacket/helmet
    By korndogg in forum For Sale
    Last Post: 04-26-11, 09:20 PM
  4. Quality Matte/Flat Red Helmet?
    By schleppy in forum General Bike Related
    Last Post: 09-15-07, 05:49 PM
