Results 1 to 25 of 39
gotta get my bike in the air
    im going to be pulling the wheels of the KTM to get them painted. i need to get the bike in the air and leave it there for a while. im in kind of a unique situation though. the bike is here at work. i can put the rear on a stand if need be but i cant do the front. my stem stand is too short and im afraid to use a fork stand as it will stick out too far and know someone will accidently kick it when walking by. i cant support it with straps from above because we have 30ft ceilings. i cant really put a jack under the frame like a dirt bike because it doesnt have a frame and the header pipe runs under/next to to the motor.
    i really wanted to get the wheels off tomorrow but i cant seem to come up with a good way to do this.
    Wirelessly posted
    Jack stands under the forks? A rod through under the front of the motor and jack stands each side?
    Re: gotta get my bike in the air
    I usually use tie downs to suspend it from the i-beam in the garage?
    cant do that. 30ft ceilings.
    degsys idea might work, just sounds sketchy.
    Just use the rear stand and let the bike rest on the forks? I've done that before too.
    Get a couple of guys and lift it up.
    Banned G21forme's Avatar
    Lakes
    Just get a pair of those metal saw horse brackets and some 2x4's and make them 6' long.
    Crane
    Lifer Falko's Avatar
    MoonTown
    I have a small portable gantry crane I made to suspend bikes, has a winch on top. Straddles the bike and you can attach lifting straps to the frame.
    You are more than welcome to you use, I just do not have any time to get it anywhere near you.
    Wirelessly posted
    Quote Originally Posted by SVRACER01
    It's not sketchy as long as the bike is on a rear stand also.
    I've had my bike up on jack stands for an extended period of time. It's not that sketchy.
    What is the foot traffic like where the bike will be? What are the chances of someone getting close to the bike?
    Waaaaiiiittt a second. Isn't the KTM a friggin sumo? Just leave it laying on it's side and turn the gas off or lean it up against the wall in a corner!
    Oxx, u got access to an A frame ladder big enough to clear the bike? You could use that to suspend the bike from. Or just lower the forks onto the ground like Smutters said. I've done that before.
    You could also get some wood blocks if the floor is too far of a reach.
    i think the plan is that im going to get a large 8 wheeled diesel crane and put it in the building somehow and hoist the bike up.
    i think i can get a crane from the bridge project up the street
    Yeah I think we can all agree that's clearly the most reasonable & practical solution.
    Lifer obsolete's Avatar
    Norf Sho
    A piece of pipe through the hole for the axle and rest it on 2 jack stands. Crane sounds easier.
    -Alex
    Wirelessly posted
    Quote Originally Posted by obsolete
    Lol. He has to get the wheel off.
    Norf Sho
    Wirelessly posted
    He can use a fork stand to get the wheel off, then transfer to what I said because he is afraid of how far the fork stand sticks out. That's how I thought of it.
    -Alex
    Two jack stands and a breaker bar through your frame.
    Or, you could way overthink this.
    Actually, the 690 is damn tough to suspend. I haven't found any stable solution. The bottom of the motor is a V and there is no frame below the head brackets. The steering head bolt is solid, so no pin stand. The rake makes it sketchy on just about any kind of jack stands...
    i knew the crane idea was the solution.
    The bike is a fucking giraffe!
    Natick
    I have no idea what it looks like, but I've seen so many times a strong ladder up front with ratchet straps to hold it up from the front.. looks pretty awesome. and sturdy that nobody would knock over a ladder
    FWIW Paul. ive seen that someone makes an attachment for yours that resembles an engine cradle. it escapes me at the moment where i saw it though
    edit: found it
    http://www2s.biglobe.ne.jp/~outex/KT...underframe.htm
    Jun 2005
    Have you tried smoking weed?
  1. This buiilding bike "themes" has gotta go
    By 9secondsflat in forum General Bike Related
    Last Post: 02-27-12, 11:15 PM
  2. what do i gotta do?
    Last Post: 07-24-04, 03:34 PM
  3. beet's Gotta New Bike!!!
    Last Post: 12-28-03, 06:58 AM
  4. I know , I'm a good kid but . . . gotta do what you gotta do . ..
    Last Post: 05-22-03, 02:15 PM
