Results 1 to 25 of 38
take-off/put-on Grips
    Toyin w/ Student Drivers JonT's Avatar
    Feb 2010
    Southern R.I.
    I ordered a R1 Throttle for my bike. i want to know how to safely take off the grip from my current throttle tube and put it on the new one with out damaging it. and what will i need to do so?
    Yowza LaRNZ's Avatar
    Oct 2004
    Tewksbury , MA
    Re: take-off/put-on Grips
    compressed air FTW
    .:|LaRNZ|:.
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16)
    What latnz said. Use a blow gun to float it off then. I use windex to put them back on.
    Lifer Danz19899's Avatar
    Grafton, Ma
    i have just wrestled mine off in the past but some can be a bitch, i've used grip glue to put them back on, dont want the tube slipping inside the grip once your done
    www.bostonmoto.com
    Ride to live, live to ride
    Lifer DuncanMoto's Avatar
    If you use only air it will not slip. 2 people makes it easier.
    If you don't have air then grip glue works great if you wait for it to cure poperly.
    Feb 2008
    Rhody
    Sounds silly, but I used hairspray. That stuff's slippery when wet, sticky as hell when dry. No issues since using that method...
    Hyper
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    No grip glue. It's messy. Spray a lot of WD40 in the grip, install, and let it dry
    Feb 2010
    Southern R.I.
    alright thanks guys.
    but why WD-40? i could understand hairspray, but i have not known WD-40 to get sticky
    Raymond NH
    Might as well put heaters under the grips while you have it apart.
    Derry NH
    Getting it off, not idea as I alway cut my old ones off. But to install new ones, I use hairspray for the above reasons.
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    FYI- I used to use hairspray. If you ride in the rain it can get wet and the grip can get slippery.
    Quote Originally Posted by DuncanMoto View Post
    So what do you use now?
    2009 RMZ450
    I don't use anything, but if I'm really concerned, I'll safety wire 'em.
    Quote Originally Posted by Neytiri
    Air only if possible.
    Grip glue if there's no air compressor.
    soldier medic neuthunder's Avatar
    Jul 2005
    boston/abington
    I cut mine off then followed progrips instruction using soapy water to put the new ones on. A blast of compressed air to dry them
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    I've heard a lot about the hairspray method but I'd like to know how they do it at the factory. I've never seen any gripglue remnants when I removed a grip.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Lifer Trouble's Avatar
    Monkton, VT
    Compressed air has given me the best result. Take a blow nozzle, slide it under the inner side of the grip and blow it while working it off. Do the opposite to get it on.
    LRRS EX #7
    Low Down Racing
    Quote Originally Posted by JonT
    Has worked the best for me. Got the tip from Ryan Nicolson on this forum. Grip glue was really messy, and hair spray didn't last.
    The WD40 worked great to slip the grips on, then holds perfectly once it's dry. If you don't believe me, test my street or track bike. Never safety wired any of my grips after trying WD40
    I will say though, make sure to use a good amount of WD40. Compressed air helps getting the grips on/off very easily.
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    I usually cut the old ones off with a straight razor....
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
    Feb 2010
    Southern R.I.
    so.... then.... should i do the wd-40? or just find some super-glue? i do have the air compressor.
    your call. i've done 4 sets of grips with WD-40 & never had an issue. I wouldnt suggest super glue. i've tried grip glue & hairspray, didnt like the end result.
    Feb 2010
    Southern R.I.
    so with the whole moisture thing... does humidity also affect the hairspray>
    Little bit of gasoline works great, or brake cleaner.
    Allows it to slide right on, just work quick if you use brake cleaner, once it evaporates, that grip is on there.
    Feb 2008
    Rhody
    Quote Originally Posted by JonT View Post
    I've personally never had a problem with the hairspray method, wet, humid, whatever...
    Hyper
  1. Driven D3 Grips
    By burtonboarder23 in forum General Bike Related
    Last Post: 08-27-10, 01:28 PM
  2. SV rizoma grips
    By obsolete in forum General Bike Related
    Last Post: 02-28-09, 02:02 PM
  3. Grips on R1's
    By Jim in forum Bike Maintenance
    Last Post: 02-25-09, 12:55 PM
  4. mmm, heated grips
    Last Post: 06-06-08, 06:16 PM
  5. "Hot Grips" heated grips
    By interceptor in forum General Bike Related
    Last Post: 11-13-01, 04:32 PM
