Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
take-off/put-on Grips
    Apr 2006
    Beverly, MA
    Re: take-off/put-on Grips
    I take a straight coat hanger (or thin screwdriver) and carefully work it around the inside of the grip (between the grip and the tube) to "break" all of the glue up. Then I used compressed air to inflate the grip and pull it off.
    Silver Bullet Commuter fjrrider RI's Avatar
    Narragansett, RI
    soapy water and a skinny screw driver pushed under the grip and then the push the screwdriver around the the tube then spray soapy water under for easy slip off, five minute job. Clean tube and push on with special grip glue (removable again later). guess air would work as well as above
    Yamaha lover
    Just Registered Doc's Avatar
    Jericho, VT
    WD40 is a solvent. Try it on your old grip, Spray it, let it dry and see how it feels (on the outside)
    I always safety wire my grips too. Just in case, plus it looks cool.
    Wirelessly posted (Instinct: Mozilla/4.1 (U; BREW 3.1.5; en-US; Teleca/Q05A/INT))
    Didnt the throttle tube come with a grip on it?
    you lose coolness points at Newbury Street if you're rocking stock grips
    ooooooh
    Toyin w/ Student Drivers JonT's Avatar
    Feb 2010
    Southern R.I.
    well i got gel grips put on not too long ago. but it would be one stock yamaha grip on a gsxr. not the best looking.
    guess i will try and hit up the local shop see what they got for glue.
    How do you safety wire it? any pics?
    There are usually grooves for safety wire.
    Central MA
    I usually end up putting a little bit of oil on a long skinny Phillips screwdriver, inserting it into the end of the bar/grip, then "walking" the screwdriver around the diameter of the grip while spinning the screwdriver. The grip will then pull right off. Wash the throttle tube and bar end down with brake cleaner before re-installing the new grips. For this I have used clear spray paint (works well), WD-40 (grips can eventually come loose), Crazy Glue (works well, but it is easy to miss spots and you will have a loose area), and Grip Glue (best - no substitute really).
    On some bikes the grips are glued on from the factory and it is almost impossible to get them off without cutting them off with a razor blade, and even then there will be a mess to clean up.
    Quote Originally Posted by JonT View Post
    i'm guessing you dont have safety wire pliers
    KB KB's Avatar
    Manchester NH
    I use primer. The cheapest kind you can find. Cut the old ones off. Spray the primer around inside and get it nice and gooey. Slide it on. Let dry and you'll never have a problem. Only thing is to make sure you cover the bike with some rags in the event some primer oozes out.
    I learned this trick from and old time hare scrambles guy. Nothing worse than a wet loose grip.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Feb 2010
    Southern R.I.
    so i got my R1 throttle tube put on. and use hair spray with a very tiny bit of grip glue for the grips.... i have to say that grip glue is by far the biggest biggest PITA ever. it started to dry before i could fully get the grips on...
    but with the hair spray, some one said that moisture can loosen up the grips... does humidity count? any one have any issues with humidity?
    hate to say i told you so....
  1. Driven D3 Grips
    By burtonboarder23 in forum General Bike Related
    Last Post: 08-27-10, 01:28 PM
  2. SV rizoma grips
    By obsolete in forum General Bike Related
    Last Post: 02-28-09, 02:02 PM
  3. Grips on R1's
    By Jim in forum Bike Maintenance
    Last Post: 02-25-09, 12:55 PM
  4. mmm, heated grips
    Last Post: 06-06-08, 06:16 PM
  5. "Hot Grips" heated grips
    By interceptor in forum General Bike Related
    Last Post: 11-13-01, 04:32 PM
