Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 126 to 137 of 137
Grom build
  1. #126
    Re: Grom build
    Also closed the Auto Tune loop that’s been gathering AFR data with the new OverRacing exhaust and 93 ethanol free fuel. It runs much smoother now on low throttle and the front tire lifts high on clutchless power wheelies.
    This NEO181 bike should be 22-23hp now. Still using a Grom motor.
    how does the frame & suspension handle that horsepower, when you go over 70, do your knuckles turn white ? I start to shake as if I had Parkinson's. I'm ok on a 400lb bike, might be nervousness when I weigh 60lbs more than the bike, or just old age
  2. #127
    Re: Grom build
    the suspension is upgraded to Ohlins front and back, so it can handle it all. the axle is the only issue i've ever worried about with the high power builds, but there are others with 40+ horsepower engines on the stock axles. The clutch has been upgraded to support the power.
    After 70+ MPH, the front wheel feels a bit sketchy, but i did get the wheels balanced this time when i had the angled valve stems added. they werent way off balance, but they needed some weights
  3. #128
    Re: Grom build
    I'm hoping the steering damper I got helps my K-Pipe above 70
  4. #129
    Re: Grom build
    Different triples to give you more trail should stabilize it at speed.
    Re: Grom build
    i havent seen them for Groms, but i wouldnt be surprised if OverRacing makes them. There's someone on the FB group building a Grom with everything from their catalog. Frame, subrame, single sided swingarm, etc. only OEM part is the harness.
  6. #131
    Re: Grom build
    We were in Thailand a week ago and I was amazed at how many Groms I saw, probably thousands in the 8days we were there.
    Re: Grom build
    Groms or Navis ?
  8. #133
    Re: Grom build
    Groms or Navis ?
    Likely a combination of both
    Re: Grom build
    This Grom has been running rough lately. Checked the plug and now I see why.
    Unfortunately these NGK 8201 plugs are very difficult to find. I don’t trust ordering on Amazon.
  10. #135
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Grom build
    That's an ugly plug
    Re: Grom build
    supplied Denso with the motor kit. they're trash
  12. #137
    Re: Grom build
    I see that NAPA says call for availabiity
    https://www.napaonline.com/en/search...lug&referer=v2
