Results 1 to 23 of 23
Are there any shops around not backed up??
    Apr 2004
    Cambridge
    I have been repairing a small ammount of damage that my bike sustained after being knocked over while it was parked and the last thing that I have to do is put the new front turn indicators, I got the smaller then stock ones, but I really dont know how to do this, I called riverside and they let me know that I was going to have to wait 2.5 weeks, then I called GBM and they said the end of the week, I really just want to put these on so I can ride again until my other new parts get here, anyone know someone or somewhere I can go?? Thank you!
    Jesse
    Arguing on the internet is like winning a gold medal in the special olympics......whether you win or lose you are still retarded!
    Dec 2003
    Ma
    I can probably give you a hand wed or thursday. It's pretty easy to wire up blinkers.
    Apr 2004
    Cambridge
    That would be great, you tell me where to go and I will meet you there.
    Jesse
    If that doesn't work out, gimme a hollar. I could help ya out Sunday, but you're gonna hafta get it up to my place...
    Senior Member slingblade's Avatar
    central, ma
    Pick up a $20 multimeter at sears (in the hardware section)
    your stock blinkers will have 3 wires; running, blinking, and ground.
    did you get 3 wire replacements? If so: put the red end of the multimeter on a wire, with the bike on. One of them will allways show voltage; this is the running. One will show voltage, then none, then voltage again. Guess what? Thats the blinker One wont show anything and that is ground. Your new blinker package should say which wires are the running/blinking/ground.
    If they are just 2 wire 'blinkers' than you just need to find the blinker as above, and the ground.
    Its pretty simple if you've worked with wires. Use wiretaps, and electrical tape or shrink tube. You'll see when someone helps ya out.
    Member gixx6man's Avatar
    Aug 2002
    Whitman MA
    Blinkers
    I think the LP has the red as the positive, black as the running, and the striped as the ground.
    Pimptastic ftrain's Avatar
    NH
    Make sure you solder those wires.
    ~ FTrain
    Lifer SEVENSGT's Avatar
    Warwick, RI
    in a word
    NO
    Dec 2003
    Ma
    solder? Pffff, I've had all my replacement lights for 3 years and not a problem yet......(plus I don't have a soldering iron)
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    i've always been told solderings actually not the best idea for things that vibrate, like bikes and cars, solder joints can crack easily if not done just right.
    Crimp-ons are typically a better idea, unless you REALLY know what your doing with the iron.
    NOT laughing with you {~; bemused's Avatar
    Deer Island, OR
    mebbe he means to tin the ends of the wires prior to crimping on the connectors... which ain't a bad idea, reduces the likelihood of corrosion over the long haul...
    jeff f
    '97 RF900R
    Mar 2002
    Amherst, NH
    thats very possible.
    a lot of that info comes from peoples opinions, i dont know what the REAL right answer is.
    i could share my personal outlooks on how i do installs on electronic things... but that would take a long time cause i am usually pretty anal about my wiring. (until recently where i was shown some neat new techniques)
    NH
    You have been mis-informed.........You want to solder wires in places with lots of vibration. I can see where you are comming because if you bend solder it will break but your statement is false. I work as a engineer in the Aerospace field and the enviroment specs are the biggest headaches.
    ~ FTrain
    NH
    If anyone is looking for any work to be done to their bike I can offer you a cheaper solution. My roomate Shawn, a Honda Certified Tech that works at Naults, Manchester and also his older brother Chris (Teach) who use to race professional both repair and upgrade bikes. There are bikes going through our shop all the time. If you need any work done to street bikes, quads, or dirt bikes let me know and their shop rates are almost half what the dealers costs and you still get a Honda certified Tech doing all major work.
    ~ FTrain
    I'm telling the Zoning Board!
    Yeah, but what happens when they work on a Suzuki?
    Mar 2002
    Amherst, NH
    hahaha, i wouldn't call my statement mis-informed, more like incomplete, cause i pre-qualified it without fully disclosing the qualifications.
    true on the solder for industry app's, but we're not building aircraft here and the average joe schmo on the street wont be putting the proper strain relief in the solder joint and would probably wad it up real bad too... hence the opinion that a crimp-on terminal will probably work better for them in the long run.
    i work in the same field, i know all too much about dealing with those kinds of specs.
    Dec 2003
    Ma
    pffff, what would the point be
    Chris actually raced a suzuki. They're good with those too.
    and as far as wiring. I'm all for the twist and tape. Like I said, I haven't had a problem in 3+ years. It's not like we're boring engines or installing NOS here.
    I've used crimp type connectors on every bike I've ever owned, and I've never had an issue with 'em. Can't argue for or against the soldering method through 'cuz I've never gone that route. But I'll be ringing you once I get this satellite project underway...
    NH
    Space is a whole other topic. I worked on a program to design remote sensing RF equipment. Talk about enviroment headache!!! I will never work for s space defense program again. Spend more time making paper trails then actual desig work.
    Yes, strip, twist, tape works. strip & crimp works, but solder and shrink wrap looks so much more sexier.
    Then again we are talking about a blinker and not a 50-60 GHz receiver to see wind currents and water level from outer space.
    ~ FTrain
    Dec 2003
    Ma
    Deer Island, OR
    and... another advantage of "bullet" type crimp connectors over solder: they're a helluva lot easier to connect / disconnect if, say, you gotta remove blinkers to remove fairing, etc.
    jeff f
    '97 RF900R
    KB KB's Avatar
    Manchester NH
    I'm calling on that statement Ftrain. I called MBR and got a pfffttttt................we're backed up till the snow hits.
    Go figure.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    NH
    Go figure.
    KB I get the same work around with them. They hate to work on my stuff because the can get paid working on other bikes. I just take stuff apart in the middle of the shop and come back in a few days to find it all put back together. Shawn hates any messes in the shop.
    ~ FTrain
  1. bike was backed into and it tipped over
    By 7UPyours in forum General Bike Related
    Last Post: 07-12-13, 02:09 PM
  2. Bike Backed Over
    By jcrawford in forum General Bike Related
    Last Post: 08-25-11, 05:57 AM
  3. My bike was backed over
    By idratherberidin in forum General Bike Related
    Last Post: 08-31-08, 05:22 PM
  4. I think I backed over something..
    By GadgettR1 in forum General Bike Related
    Last Post: 07-17-04, 07:57 PM
