Results 1 to 25 of 35
help
    Just Registered newgixxerchic's Avatar
    help
    does anyone know of someone that can weld titanium either tonight or anytime before sunday. I don't care where or how much, but I broke off the plug that takes the place of my o2 sensor on my exhaust... can anyone help me out with a name and number so I can get my license this sunday?
    Re: help
    I'm almost afraid to ask how this happened...
    Why not just match up a bolt from a hardware store?
    Re: help
    Well I guess the exhaust is broken in
    shoot a PM to GMDBoston. I hear he can weld trees.
    Jun 2005
    Re: help
    It's a real bitch, but I can TIG it. I got fuckin no Ti filler rod, though.
    You have a swanky ti exhaust, right? Arrow? I'd take it to someone who does a lot of Ti (I don't).
    It ain't like welding steel, that's fo sho. Your average welding shop will probably just burn holes in it.
    Re: help
    so i was partially right on the other thread
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: help
    again the freeze plug for the O2 sensor popped out, somehow the welds gave way and the pressure popped out the plug.
    From what i could see its not threaded but i could be wrong it was dark out and i couldn't get my finger all the way in to be sure........
    Jun 2005
    Re: help
    Quote Originally Posted by R1slowflyer View Post
    I don't really even have to make joke here. This shit stands on it's own
    Lifer R1's Avatar
    Re: help
    I had something to type up after it but i figured you can all have your fun!
    Re: help
    Sounds like you should call the manufacturer of said exhaust.
    Re: help
    "freeze plug"??? wtf is a freeze plug doing on an exhaust system?
    You mean a secondary O2 bung?
    (I said bung )
    Member TimD's Avatar
    Woburn
    Re: help
    I think I could do it... no promises for it being pretty though.
    Tim
    '05 GSXR1000
    Lifer R1's Avatar
    Re: help
    (I said bung )
    all i know is that there was a freeze plug or similair in place before, and its gone now! and it was from what i recall spot welded, i am not 100% sure, but yes it is strange. it is where an O2 sensor would go, but in the instructions for the exhaust itself it came with directions on how to override the O2 sensor as if not to install.....
    very confusing and with our license test coming up on sunday looks like ill be on a harley and she'll be on the R1......
    Lifer R1's Avatar
    Re: help
    Quote Originally Posted by TimD View Post
    pretty or not it may be a last resort. ill let you know by tomorrow and we can see if we can work something out.
    Re: help
    No crappy exhaust that's falling apart on my 929 that's for sale......think about it...
    Lifer R1's Avatar
    Re: help
    dude if it weren't for the tax man i would have considered it especially with the nice chunk of change i am hoarding til i have to write that last check.
    Re: help
    as of right now I'm in contact with PK to see if he can get it in by this weekend
    Thanks for everything so far...
    Re: help
    Quote Originally Posted by g®eg View Post
    you're going to be there too?
    great.
    should be able to just plug the hole no?
    Very nice to meet you this morning... Yeah Keith is taking the course too. We're working on getting a place to plug the hole, but it's titanium so it's a little more difficult and I don't want to worry about not passing "inspection."
    Senior Member klepsta's Avatar
    Feb 2008
    Stoneham
    Re: help
    Is the bung being welded back in or is it going to be sealed up with a plug? I can do it, but I dont have any Ti filler here, I would need to pick some up.
    Steve
    Work Hard---Play Harder
    Re: help
    I don't have the bung, so I'm assuming it will be sealed with a plug. I have a place that might be able to get to it, if I pull off the exhaust myself. It's obviously mid pipe so in order to block both sides of the pipe to weld, I have to take the exhaust off... Not good timing right now
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: help
    Alicia,
    If you still got the stock exhaust, throw that mofo back on for inspection. When you're done put the Arrow POS back on. Temporary solution to your time sensitive problem.
    Re: help
    it is a possibility, but there would definitely be more work as I would have to disconnect items relating to the PC3 mapping i would think...
    Feb 2006
    Metro West, MA
    Re: help
    Quote Originally Posted by newgixxerchic View Post
    You can leave it connected it wont cause any harm with the stock exhaust. All the PCIII does it smooths out your powerband and gives you some slighly extra HP.
    If you're not comfortable with it running just disconnect the power to the PCIII and the stock ECU mapping will run. Once you restore power to the PCIII, it will override the stock ECU mapping like it is right now (I could be wrong so I leave this open to correction if needed).
    Re: help
    that sounds logical, but keith is removing the arrow exhaust right now, and he said the o2 sensor hole is threaded so worst case scenario, we buy an o2 sensor and just don't connect it... it'll be a dummy, but that may be a better route than welding a new plug there.... who knows...
    Lifer R1's Avatar
    Re: help
    it'll be a dummy...
    Thanks babe.
    all this work i am doing and you go and insult me
    off to DAS for a little one on one with a tig welder.
    Re: help
    why not just put a bolt in to block the hole for the time?
