Results 1 to 14 of 14
Hydraulic Clutch Bleed Clue?
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    I'm wondering if the Master Cylinder has a leak at the end of the piston where the lever attaches. TINY bubbles come up from the piston area under the resevior, once and a while.....
    I've gravity drained, cleaned and put ~14oz of new fluid through the clutch resevior.
    I've bled the system by using a clear hose on the
    bleeder screw.
    Pull the clutch lever, Hold in........open slave bleeder screw, watch fluid come out, close bleeder, then release clutch lever.
    Do again and again and again..more than 14 oz worth over 3 attempts.
    No clutch action.
    Amount of brake fluid discharged varies on bleed attempt.
    In other words, sometimes a little comes out and others its 3x more fluid in the clear line.
    Any BTDT on what I'm doing wrong?
    No Mity Vac here. Thinking of a reverse bleed somehow.
    -Suf Daddy
    Suf Daddy.
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    Do you build up any resistance in the clutch lever when you pull it in? If not, I would start looking at the Master a little more. If you do, does the Slave cylinder move freely or is it frozen.... Had to rebuild the slave on my FZ750 when it froze up on me.
    Just a couple of thoughts
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Nov 2003
    Resistance?
    It doesn't feel like it.
    Seems the same (easy) no matter how I pull it or bleed it.
    -Suf Daddy
    Suf Daddy.
    Senior Member slingblade's Avatar
    central, ma
    You've bled the lines out, but there is an air bubble up top.
    You need to crack open (loosen) the Banjo bolt up top. Put a rag underneath it (DOT4 fluid will MESS UP paint...) and slowly squeeze the clutch and just before its fully closed, tighten the banjo bolt back. Then clean up the mess; and retorque to spec
    You'll want to rebleed real quick at the bottom.
    I fought the same thing, took me a few minutes to figure it out.
    Gone Fishin' trackdog's Avatar
    I have a Mighty Vac if you would like to borrow it dude.
    I still love the smell of burnt racing fuel in the morning!
    Nov 2003
    Yeah baby!
    Gary:
    Thanks for the offer! I may take you up on it.
    I actually have one (which was NOT in the 3 places I looked) so I may bite the bullet, but I'll try Slingblades' banjo crack too.
    I have a Movit car pressure bleeder but the hose is WAY too thick.
    I can do European cars quick like.
    -Suf Daddy
    Suf Daddy.
    KB KB's Avatar
    Manchester NH
    Crack your banjo!!!!
    That makes me think of the BANJO MINNOW...........don't know why.
    Then crack a beer!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Nov 2003
    MOUSE PAD
    I think I want to crack that mouse on your AVITAR !!!!!!!!!!!!!
    -Suf Daddy banjo cracking later.
    Suf Daddy.
    Nov 2003
    WE HAVE A WINNER !!!!!!!!!!!!!!!!
    Slingblade and RMBbikes!
    Two cracks, TWELVE seconds and clutch action BANG! right on!
    You guys beat the Blackbird dedicated web site on this one!
    True experts I do declare. Top reservior banjo went Spfffftttt!!!
    That was it!
    -Suf Daddy
    Suf Daddy.
    KB KB's Avatar
    Manchester NH
    Nice work Banjo cracka!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Nov 2003
    REWARD!
    Stop me for a cocktail or beverage Sprrfffffttttttt!
    -Suf Daddy
    Suf Daddy.
    KB KB's Avatar
    Manchester NH
    I work in concord and head through lincon on my way home. I'll be looking for you.
    Keep your eye out for a Red Superhawk that is smoking at every stop light.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Nov 2003
    Middleton/Danvers, MA and Lincoln NH
    Or Cape Cod for that matter....... I'm everywhere!
    I owe ya!
    -Suf Daddy
    Suf Daddy.
    central, ma
    Glad it worked
    After doing who knows how many normal brakes, this one stumped me bad for a little while. I must have 'bled' the clutch for 20min straight thinking WTF is wrong. Then it dawned on me.
  1. Install a Magura Hydraulic clutch on a wr250f
    By black in forum Dirty Bastards
    Last Post: 04-09-22, 06:05 PM
  2. Hydraulic clutch issues
    Last Post: 10-03-16, 05:57 PM
  3. Bleed coolant..
    By cdseven95 in forum General Bike Related
    Last Post: 07-06-10, 07:18 PM
  4. Clue Removal!?
    By JunoAF in forum General Bike Related
    Last Post: 08-14-08, 10:03 PM
  5. Is Buell FINALLY Getting A Clue??
    Last Post: 08-18-01, 09:28 AM
