Results 1 to 17 of 17
Lowering my bike
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    Lowering my bike
    thinking of lowering my street bike 08 cbr 1000rr by 1 inch.
    i have a trackbike so no....this bike is not going to see the track.
    what are the cons? will it change the bikes corner handling that much?
    is it safe?
    anybody know of a good link to diy lowering your bike?
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    Ray Viernes, Scammer! Ray-Ray's Avatar
    Oct 2009
    Re: Lowering my bike
    lowering the suspension changes the handling first of all because it changes suspension geometry. on a street cruiser that's ok, but on a highly tuned sport bike it's not a good idea. if you do find that you absolutely want do to it though, make sure you lower front and rear the same amount to keep the geometry as unchanged as possible. not a good idea though. the easiest and best way to lower a bike is to make the seat narrower and lower both so your legs are closer and therefore reach better. more confidence will allow you with more time to feel more at ease keeping balance on one foot.
    Oct 2009
    Eric...I can come by and lower it for you as soon as you get the links or dog bones. I like Sam adams
    Quote Originally Posted by j4eric View Post
    is it safe?
    Yes, it'll change a little bit... probably not by much.
    Sure, it's safe.
    Talk to PK if you wanna do it "right".
    Or, shave down the foam on the seat. Probably the cheapest option and maintains handling.
    Sure, it's safe.
    As mentioned, lower the front and rear.
    The front is simple, just slide the fork tubes up in the triples to lower the desired amount. The rear, buy a dogbone link and just swap it out. I'd get an adjustable link if it's available for your bike.
    I had a 1998 R1 I lowered for drag racing. It had an adjustable rear link and I just slid the fork tubes up...I think I could lower it to almost 2". At 1", the handling was similar, but at 2" is was quite a bit more noticeable. You may also have to shorten your kickstand
    The question of whether or not it is "safe" is only if you're going to extremes, IMO.
    I didn't realize it years ago but after a few years of racing I realized how often racers adjust ride height in order to get handling characteristics that makes them happy.
    Cons are: If you go too far and your front fender or rear tire whack the underside of some other component on the bike....oh, and the sidestand eventually becomes an issue.
    Banned G21forme's Avatar
    Lakes
    You'll be fine
    Aug 2009
    Grafton, MA
    okay, thanks guys, this will be a project for me hopefully by thanksgiving.
    Ray, i might take you up on that offer, i can do it, i just need a wingman..will let you
    know once i have all the parts.....and the Sam's
    i found adjustable kickstands on ebay....a little expensive but its perfect for a poser bike.
    99 R6 track bike
    Before you buy a kickstand, stick a 1" thick piece of wood or something under it to see how it will sit. You may not need that thing.
    Aug 2009
    Grafton, MA
    Will do Pete..you might have saved me some $$ there.
    99 R6 track bike
    Oct 2009
    Eric I'm right down the toad from you so let me know. Would be cool to catch up buddy.
    Dec 2003
    Ma
    You'll shoot your eye out kid.
    And it might be even cheaper to shave the seat instead
    Dont do it you could DIE in a Fire...
    Aug 2009
    Grafton, MA
    I have louimoto seats....i dont think i want to shave the bling....
    99 R6 track bike
    why are you looking to lower it Eric?
    Providence, RI
    i had mine lowered for a couple years, took it to the track that way too, wasn't HORRIBLE. i don't know how the 1000rr is set up, but on my 600rr you can rotate the triangle bracket that attaches to the dogbone and lower it about an inch for frizee! but here are some other things i did as a vertically challenged person:
    http://viewfrom60.wordpress.com/2011...ing-your-bike/
  1. lowering a bike?
    By Adrenalinechic in forum General Bike Related
    Last Post: 09-23-08, 03:07 PM
  2. Lowering 03 CBR 600RR
    By wortown03 in forum Bike Maintenance
    Last Post: 11-20-07, 04:32 PM
  3. Lowering a 250 Ninja?
    By bmrider in forum General Bike Related
    Last Post: 07-25-07, 02:58 PM
  4. lowering my bike??
    By sublime2e3 in forum Bike Maintenance
    Last Post: 05-04-07, 07:34 PM
  5. lowering bike
    Last Post: 08-06-03, 09:01 PM
