Results 1 to 10 of 10
pipe question
    I Dance With Will
    Oct 2002
    unknown
    Question pipe question
    i remember a discussion about after market pipe in a car. if you run the pipe straight, means you gut the catalyst, you lose some back pressure which means the car suffers low end torqu. for a turbo model, this is not a big deal because the turbo will spool up quick enough to make up the lost.
    my question is this true for motorcycle espacially the 600 as they have low enough mid range torqu?
    "fuckit!"
    Senior Member JJ's Avatar
    Aug 2002
    Ashland NH
    pipe question
    I remember a story about racing (cars) and they enforced a muffler rule. All the engine builders were bitching about it untill they found out they could make more hp with a little back pressure. IMO that is why Harley's have alot of engine problems becasue they run drag pipes with no back pressure and burn the motors up. Now if your making top fuel hp 7-8000 then I would have to say that back pressure would hurt but you also notice they rebuild every run. You should make this a poll I guess. I vote for back pressure here.
    That thing got a KAWI in it?????? SWEEEEEET!!!!!!!
    1997 ZX7R LATER JJ
    I Dance With Will
    Oct 2002
    unknown
    pipe question
    im wondering if most people also upgrade the fuel management when they changing out the pipe for either more gain at high end or just compensate for a lost at low end. if not is it an automatic gain? just throwing this out.
    "fuckit!"
    Aug 2002
    Ashland NH
    pipe question
    Keep in mind bigger isn't always better. To large of an injector or carb can hurt performance just as to big of an exhaust can do the same. But to small of the above can also rob performance. So your best bet is to find out what size pipe, fuel, etc to run for the hp you are capable of making. I think most people run open exhaust becasue they think it sounds cool and they aren't really worried about overall performance. If it sounds like it will run 10's more than likely it won't..... just watch Fast and Furiuos .
    1997 ZX7R LATER JJ
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    pipe question
    Calling TLRMAN please bless us with an explanation before we theorize ourselves into stock setups.
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    I Dance With Will
    Oct 2002
    unknown
    pipe question
    "fuckit!"
    Senior Member Green Hornet's Avatar
    Connecticut
    pipe question
    Back pressure is needed, but it depends on the appication.
    It depends on what kind of power curve you're looking for. For a comprimise like on the street, back pressure is good because you don't loose out on the low end, mids or the top end.
    This is why high end pipes like Arrow or Akrapovic are tuned to specific motorcycles to max out the entire power band, which in turns end up making the bike faster then a straight thru design like D&D.
    on and on, South of Heaven
    Northshore/Beverly, MA
    pipe question
    Ha! Now you've done it....
    Lets start with "Forced Induction"
    If you are using a blower or Turbo, you don't need back pressure..
    You don't need the reversion, or reverse pulse of the exhaust wave to "push" some of the lost air/fuel charge back into the cylinder ...Does the term over scavange sound familiar?
    You get a very fresh air/fuel charge with forced induction, and no leftover exhaust gasses present.
    For "naturally aspirated" applications, it's nice to have some..for the reasons I stated above. Some of the fresh air/fuel, makes it out of the cylinder, during the exhaust and intake valve overlap event. At lower RPM's the cams allow the valves to flow more than the engine requires so back pressure helps. Seems like everyone is using the EXUP concept these days because it works...
    Once the rpm's get to where the cams come in, you don't need it as much...On 2 cycle applications, the "Tuned Pipe" or expansion chamber does return a pulse back to the engine, and supercharges it from the exhaust port.
    Take a look at the "stinger" on the those pipes, they are a lot smaller than the head pipe. There are a lot of other factors involved, such as angles, belly lengths, and convergent cone
    angles, as well as stinger diameters and lengths..If you are really interested in this stuff, Look up a fellow by the name of Dr. Gordon Blair of Belfast University.. He is the #1 guy when it comes to 2 cycle technology, and I was fortunate to have a friend that studied under him...I had lots of questions answered, that I couldn't prove that worked, 20 years ago.
    JJ,... bigger injectors just mean more fuel....You must have meant bigger throttle bodies....
    Member ducatiboy's Avatar
    May 2003
    middleboro
    pipe question
    sounds like you know your stuff.
    I Dance With Will
    Oct 2002
    unknown
    pipe question
    you questioning the doctor?
    "fuckit!"
  1. K-Pipe
    Last Post: 06-26-23, 06:31 AM
  2. dent in my pipe
    By burnham in forum Dirty Bastards
    Last Post: 04-01-10, 08:18 PM
  3. R1 MJS Y-pipe
    By Quigs in forum General Bike Related
    Last Post: 08-22-09, 05:52 AM
  4. Need 03' 636 pipe
    By NINJA_GIRL750 in forum General Bike Related
    Last Post: 07-01-09, 01:22 PM
