Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
short/long stroke
    Mamasita LatinRider's Avatar
    May 2003
    Boston, Massachusetts
    short/long stroke
    Thanks Pat....
    Anytime Mark
    I myself am... strange and unusual.
    I Dance With Will
    Oct 2002
    unknown
    short/long stroke
    that is awsome, 300hp from 1.6.
    i know their is a water jet kit that is selling out there if you'e to increase the comp on some turbo cars. how well this works.
    "fuckit!"
    Walpole
    short/long stroke
    There is a BMW M3 that my buddy works on in his shop that is using a supercharger and water injection. With all of the mods he has done to this car it is producing about 500 hp. It is a really scarry and fun car to drive. He told us that without the water in there he wouldn't be able to push it that much because of the heat.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    been around long time anty knock
    works 2
    a little af in the chamber makes 1 cean cil.
    ever see after head gasket blows clean
    www.bostonmoto.com
    Forum Rules
    Northshore/Beverly, MA
    short/long stroke
    We used water injection on a 78 camaro...Used Garret turbos, Yes...2 of them...but it was a wet system. had a priority valve, that would pull air/fuel thru the manifolds before the boost went positive. But when positive it would pull thru the carbs into the turbos.
    Did all the other tricks, like my Mitsu..Titanium valves.."O" ring the heads, rods, pistons...Was 355 cu in, and plastered the chasis dyno at well over 700 hp. Used lots of water! Actually it was a water/alky mixture, and had a similar timing retard unit installed. MSD made/makes good stuff! The compression ratio was at 8 to 1. if I remember correctly...
  1. long story short
    By RS117 in forum Welcome and Intro
    Last Post: 01-08-12, 06:05 PM
  2. short/long practice format staying?
    By brady in forum Pit Area
    Last Post: 08-08-11, 11:43 PM
  3. short story long
    By SVRACER01 in forum Pit Area
    Last Post: 04-30-07, 04:19 PM
  4. Short Story Long....... (a photo journey)
    By mzdagrl in forum General Bike Related
    Last Post: 04-24-07, 10:24 PM
