2000 zx6r
just got done 2 trackdays last weekend, bike was fine other than maybe an issue squealing with brakes when engaged remedied by new pads
rode the bike to work yesterday and today. yesterday no issues.
Today i hear a squealing/squeaky noise.
I thought the brake pads were rubbing.. head home and swithc them out... again
go to my girls house tonight for dinner and it get worse.. seems like its comign from the "clutch area" i start to get worried and think that the clutch will seize up
gears engage fine however.... i hear a cyclical/rhtymic squeak
squeal noise.
it tends to decrease when pull in the clutch..
and it does not get worse when i rev the engine.?
when I got home I spun the front wheel and all seemed normal
tonite i'l put it on the stands and running it thru the gears to replicate the problem. so i can hear the sound.
any ideas??
it ran fine at the track.. it all of a sudden sounded wierd. it sounds like something is rubbing... and happens in all gears too almost sounds like a squeaky wheel but it isnt, i tightend up all the bolts too
hmmmm......
sure it's comin from the right side? I'd look at the chain first, that's the easiest fix.... check tension & lube.
