Results 1 to 12 of 12
new taillight wiring question
    Jan 2007
    Question new taillight wiring question
    the new tail lights that came with my under tail have 3 wires comin from each light and the stock harness has 3 wires from it. obviously the ground is black so i hooked that up and when i hook us the other 2 the light comes on but doesnt get brighter when i pull the brake and if i switch the other 2 wires and leave the ground the same thing happens.. any idea on how to do this the right way? thanks
    Quote Originally Posted by hyooz2004 View Post
    Sounds like black is your brake light line. Don't go by normal color conventions. Meter the wires out to see which is shich.
    derek
    Jan 2007
    yea i figured out the light problem.. now when i pull the brake it lights up but its not that bright. the tail lights itself are bright but the brake lights arnt that bright.. any ideas that will make it brighter? different bulbs? i might add some red leds somewhere i guess
    The bulb is installed 180 degrees off. The wrong filament is lighting when you press the brake lever. Or there is a bad ground on the brake circuit.
    Jan 2007
    thanks man that 180 degees off made sence but i tried to reverse the bulb and you can only install it one way.. could i safely increse the wattage with a new bulb or will it overheat?
    Lifer ZX-12R's Avatar
    Candia, NH
    This is one of those situations where the best answer is "it depends." Most likely the increase in wattage won't be that great so you shouldn't have any problems. Lights with intermittent usage like directionals shouldn't have any roblems. You should be a little more careful with any lights that are on continuously (like your tail light).
    If you are switching to LEDs, heat won't be an issue.
    I hate Harrison tjspeed3's Avatar
    Aug 2004
    Could it be that the brake wire and the tail/marking lights wire are swapped?
    Tom J
    LRRS #703
    May 2005
    Bernardston, MA
    So switch the wires.
    Jan 2007
    tried that
    my experience is ground is brown
    No! If it's brown, flush it down! Where've YOU been?
    Lifer Punjistick's Avatar
    Norwell, MA
    if it's yellow, let it mellow
  1. Safety wiring question
    By MaRce1o in forum Pit Area
    Last Post: 04-03-17, 05:33 PM
  2. Question about wiring rear sprocket
    By DZircher in forum Pit Area
    Last Post: 02-04-13, 08:14 PM
  3. Another voltage question... camera hard wiring
    Last Post: 04-19-09, 10:09 PM
  4. stupid wiring question
    By smf in forum Pit Area
    Last Post: 04-22-07, 08:43 AM
