Results 1 to 5 of 5
TRX90 shifting issues
    TWINS! xrocket21's Avatar
    Central Maine
    2001? Honda TRX90
    This thing always ran fine, then one day a kid came in and said it wasn't shifting right. It drops right into first, but wont really go into second. If you push really hard you can get it to shift. Downshifting is equally difficult. You can get it to shift, but it takes multiple tries and doesn't shift well at all.
    Research says usually it is the star shaped shift pattern part that wears, the bolt is loose, or the clutch needs to be adjusted. see here:
    I pulled this thing all apart and everything looked fine, the star was fine, and the bolt wasn't loose. I adjusted the clutch, turning in until contact, then backing out 1/8 turn and tightening the jam nut. STILL shifts poorly. Seems to shift a little better, but the shifter still hangs up, when downshifting Ill have to pull up a little, and can feel it kind of reset, then I can downshift again.
    No clue how this thing went from shifting fine to shifting like crap.
    Anyone run into this before?
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Re: TRX90 shifting issues
    TIMMYDUCK
    Could be shift forks or shift drum too.
    Central Maine
    Linked in the first post...
    Central Maine
    Ill pop it back open and take some more pics.
    I have a carb kit on the way as well.
    This thing was a one pull wonder for years and now its breaking my balls
    Kinda wanna just sell it but its a good guest rig
  1. What is a 2001 Honda TRX90 worth?
    Last Post: 05-13-22, 11:09 AM
  2. Clutchless Shifting
    Last Post: 02-09-12, 10:54 PM
  3. GP Shifting
    By nhtodd in forum Bike Maintenance
    Last Post: 08-03-11, 11:31 AM
  4. 92 F2 Shifting issues
    By Deere444H in forum Bike Maintenance
    Last Post: 04-08-10, 04:33 PM
  5. Clutchless shifting..
    By bump909 in forum Bike Maintenance
    Last Post: 07-03-05, 12:15 PM
