why not do it yourself?
http://www.tigerfoam.com/
I have used these before and its SUPER easy. They say to wear the PVC suit and mask but in a well ventilated area its not bad. You can get 2 LARGE ones and that may do the entire garage (well walls that is) for 1200.
2006 Ducati Monster S2R800
Check your coverage. The big kits cost $610 each and covers 43 cubic feet. If you spray your walls 4" thick and they are 8' tall that means you can do 19 linear feet of wall. I forget the size of your garage but by the time you do the ceilings, walls, and floor you might be better off paying someone else...
LRRS EX #7
Low Down Racing
Is that stuff like R40808097986807566895. That is 'spensive!
-Alex
"MEOWW" Black Kitty will get you for knocking down the best mouse lodge around
or something like that
Hey Doc you ever see that movie "Better off Dead"? "I want my two hundred dolllars"
Originally Posted by hammadown .....The rule is:
Doc, just thought of something. One of my biggest wishes was that my compressor could live in a room other than the one I'm working in.
Your 4' crawl space would be PERFECT for a horizontal compressor.
Of course you can't do much about it now, but when the time comes I'd recommend having your electrician put a drop close enough so that once all of the permits are signed off on you can do it little DIY-ing.
ummm
I have been looking for your C of O, it is with the manual which is somewhere in a box at the house.
did you get your other goodies ... B of S?
Got your message that the 450 rocks the track![]()
Mason should be here tomorrow...
Pics please?
Rain is delaying progress.
Any Lanscapers in the area? I am gonna need some assitance building some retaining walls and stairs...
Big Pile of dirt.
You're going to kill me for this question but I'm going to ask it anyways:
Shouldn't those footings be 4' deeper? If you are going to have an open crawlspace below the garage the footings should be 4' below grade that finish grade...
LRRS EX #7
Low Down Racing
Awesome! You should start a "garage build" thread over here by the way:
http://www.garagejournal.com/forum/forumdisplay.php?f=7
I'm confused by the footings as well. They look to be about 12" deep. I thought they had to be a standard 48" deep (below frost line). Huh. But then again, I'm not a builder by any sense of the word!
Also picked up a 45000 btu Reznor, hanging heater. Anyone have a BIG propane tank kicking around?
Code requires that bottom of footing be 48" below grade to make it a legal frost wall.
Also, did they bother to compact any of that soil? Looks to me like they filled and dug where they needed to and patted it down.
Did you pull a permit for this? If so how are they getting away with this?
This is what I was expecting to see:
LRRS EX #7
Low Down Racing
Well if there is a permit then I guess the city will be by to put in their $.02 on the 12" deep footers. I just hope they stop by before the blocks go up.
