Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 201 to 225 of 333
ATTENTION IN THE HADDOCK! - Endurance Race!
  1. #201
    ...inside the van. loudog's Avatar
    Central, MA
    Re: ATTENTION IN THE HADDOCK! - Endurance Race!
    I found a seat on a...
    125 BOOM!
    And...I'm in. Was recruited by BJ Worsham for his team on charlie's ex500.
    Nice!!! Glad to hear you speed demons are in...
    Retired LRRS/CCS EX #212 | Woodcraft | Armour Bodies | Dainese USA |
  2. #202
    Good thing we had 2 front ends . Johnnies little insident tweeked the f4. Belly pan was deemed the issue for the oops in T2. We are good at swapping front ends out now. back to the f2. at least the bike is back to ballanced with the stock Hawk rear shock. Please leave us plenty of room out there the wallow is going to be hard to control.
  3. #203
    Lifer union's Avatar
    Blackstone, MA
    If anyone needs a last minute replacement let me know.
    James
  4. #204
    Just Registered Doc's Avatar
    Jericho, VT
  5. #205
    Don't worry...I'll just pass you guys on the inside.
    KB KB's Avatar
    Manchester NH
    I have an EX and a team ready to go the 400 didn't work out so well.
    It will be
    James Folan
    Bill Coolahan
    David Olivares
    Thank you to Steve Heider for the ride!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  7. #207
    It will be
    James Folan
    Bill Coolahan
    David Olivares
    I'm guessing the RSP team bailed then?
    Yes...
    Rochester, NH
    Fack, I'm suddenly looking for a seat in this event. FZR cylinder was cracked. Hit me up if you need a fourth!
    I can put a call out on the lists for a 400 cylinder?
    I would strongly advise AGAINST aiding the enemy in this case. After all, KB's loss is our gain!
    Roland Arsenault
    LRRS and USCRA #763
  10. #210
    ECKracing mostly representing.
    4 members in 4 teams.
  11. #211
    Central, MA
    It will be
    James Folan
    Bill Coolahan
    David Olivares
    Sweet! More fun people.
  12. #212
    Jericho, VT
    Gino, you need to come back to your MABE/T1a roots for this race.
  13. #213
    Hiram, ME
    Fuckers...next year.
    Jericho, VT
    Come up Kurtz, We need help in the pits and you can be our Tire tech.
  15. #215
    Lancaster, CA
    More like, forgot to talk about it for two months.
    Bill Cool --- CRA EX 47, CVMA EX 478 --- 2025 CVMA F40UL Champion, 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle / Bison
  16. #216
    Jericho, VT
    Quote Originally Posted by Mustang View Post
    There is still time!!
  17. #217
    Fail.
    Just a a heads up I believe USCRA requires the throttle cables to be wired as well.
    Fail.
    I can confirm that. That includes to the throttle and any inline adjusters.
    USCRA Pre-Race Tech Inspection Form
    Riders: Please inspect your machines prior to tech inspection. Below is
    a checklist to assist you with safety compliance for USCRA racing.
    In addition, please be sure your machines are clean enough that all
    of the below items can be clearly seen by the tech inspectors.
    Date:_______ Rider’s name:____________________________________
    Rider’s number:_______ Bike:__________________________________
    Safety Wiring
    _Throttle cables
    _Oil lines
    _Brake cable, front
    _Oil galley plugs
    _Brake cable or rod, rear
    _Oil drain plug(s)
    _Brake caliper bolts
    _Oil filler cap(s)
    _Brake arm bolts
    _Exhaust springs
    _Front fork pinch bolts
    _Exhaust nuts
    _Front axle, including nut
    _Exhaust tail sections
    _Rear axle nut, inc. bolt
    _Rear brake torque arm
    _Front brake torque arm
    _Other______________
    _ No antifreeze in radiators
    _Sidestand removed
    _Centerstand removed
    _Kickstart pedal removed
    _ Engine kill switch mounted
    and connected
    _ CB350 output shaft seal
    retainer installed
    _ Engine breather tube(s) end
    secured in closed container
    Tires, front and rear:
    tread
    depth
    _rubber condition
    Wheels:
    _Bearing play
    _Spokes (intact and
    _tightened)
    _Metal valve stem caps
    Brakes:
    _Stopping power (individually)
    _Lever free play and release
    _Shoes/pads wear
    Chassis:
    _Steering head bearings play
    _Swingarm bearings/bushings
    _Catch pan construction
    and mounting
    (min. depth of 1”;
    absorbent pad in place)
    Controls/Cables:
    _Throttle return
    _Throttle cable(s)
    _No frayed wires,
    operates without binding
    _Brake cable, front
    _Brake cable, rear
    General Machine Preparation _Clutch cable
    for all you cheaters out there.....
    12.1 Period IV, Formula 3 classes
    Period IV, Formula 3 classes will be added provisionally for 2011 season
    and run concurrently with Modern 125GP.
    Eligibility cut-off: Dec. 31st, 1989, no updating beyond this year.
    Similar, later models without performance improvements may apply in
    writing for approval.
    • 125cc, 2-stroke GP
    • 500cc, 2-stroke singles
    • 400cc, 2-stroke street based twins and triples
    (must have original frames, cylinder blocks and engine casings)
    • 400cc, 4-stroke four cylinders
    • 650cc, 4-stroke twins
    • Unlimited, 4-stroke singles
    (Exception: Suzuki GS550, Kawasaki EX250/500;
    current models allowed).
    Rules applicable to all Period IV, Formula 3 classes:
    1. Engine: Internal modification limited only to period type.
    Normal induction (no forced/ram air, except where OEM in Formula
    3). Airbox and toolbox may be removed.
    2. Carburetion: Any period carburetors permitted.
    3. Liquid cooling: Machines must run water only and flush system
    completely. Antifreeze prohibited. Water WetterŪ permitted.
    4. Frame: Original or period aftermarket frame (e.g: Harris, Spondon, etc.).
    Frame bracing permitted, if executed in period and workmanlike
    manner. With the exception of Formula 3, Four cylinder restricted to
    steel frames in period. (i.e: NO GSXR, FZR).
    5. Forks/Shocks: Conventional front forks of period construction
    and size. Monoshock and monoshock conversion OK.
    6. Bodywork: Aftermarket permitted, period styles and materials only.
    7. Brakes: Period brake systems/components only.
    8. Wheels: No restrictions.
    USCRA 2012 Rules Committee Meeting Summary
    Proposal 1: Adopt the use of transponders for all events.
    Resolution: This topic was discussed and will be tabled for the time being. There are
    issues concerning costs and having to potentially employ NHMS to facilitate
    electronic scoring.
    Proposal 2: Race results should be posted to the official USCRA Yahoo message
    board/website within (7) seven days after conclusion of event.
    Resolution: Scoring for any event will be the responsibility of the Race Director(s). Race
    Directors are to collect all scoring sheets and final results by the end of a race
    event and should transcribe and submit those results electronically to the
    Webmaster within seven (7) days of the conclusion for that event.
    It should be noted that Peter Booth has assumed the role of Webmaster for
    the club. In addition, Shane Rivet will help to create a spreadsheet that can
    be utilized for scoring purposes. This spreadsheet will be made available to
    Race Directors. Thanks guys!
    Proposal 3: Please allow floating rotor for (single disk only) bikes in HWSV class.
    Resolution: This proposal was not passed. No rule change will be instituted.
    UH Ohhhhh. no problem for our bike.
    Proposal 4: Allow tire warmers in the Formula Singles class.
    Proposal 5: Please allow me to run a turbo kit on my sidecar, but only me – Marcus #98
    Proposal 6: Masters to be split into 250cc or less and above 250cc. The only age
    requirement should be fifty and over. There would be only two classes
    not four as exists now.
    Resolution: Masters will now be one class and eligibility is as follows: 350cc and under/
    over 350cc minimum age requirement is 50 years of age as of the date of the
    event. Eligibility will remain for Period I, II, and III machines only.
    Additional topics discussed and voted on:
    • Regional Rep sought: With the passing of Jim Howes, a new regional rep is needed
    for the Massachusetts/ East region. If any member is interest, please contact
    Doug Donelan at cemoto68@yahoo.com
  20. #220
    How do you wire a throttle cable? Is this at the tube side or the carb side?
  21. #221
    With safety wire and safety wire pliers
    BTW...we ended up swapping safety wire pliers. I want mine back!
    Mine are the ones that stick. They're Motion Pro.
  23. #223
    Lancaster, CA
    Do we actually have pits setup on cold pit, NASCAR-style? i.e. would an EZ-UP be useful...or do we just have to go back to the garages to swap riders, get gas, etc?
  24. #224
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    Oh, my gooodness!! God help me. So many deviants, sooo much time!
    Oh, the humanity!
    Stop the madness! Think of the children!
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
  25. #225
    will you be shaking your head for 3 hours from the tower or will you be getting some sun with us?
  1. Replies: 15
    Last Post: 05-17-22, 07:22 AM
  2. Replies: 28
    Last Post: 06-13-18, 10:56 AM
  3. Replies: 78
    Last Post: 06-22-16, 08:45 PM
  4. Replies: 39
    Last Post: 05-20-14, 06:22 PM
  5. Replies: 36
    Last Post: 09-27-11, 05:29 AM
