Good thing we had 2 front ends . Johnnies little insident tweeked the f4. Belly pan was deemed the issue for the oops in T2. We are good at swapping front ends out now. back to the f2. at least the bike is back to ballanced with the stock Hawk rear shock. Please leave us plenty of room out there the wallow is going to be hard to control.
I have an EX and a team ready to go the 400 didn't work out so well.
It will be
James Folan
Bill Coolahan
David Olivares
Thank you to Steve Heider for the ride!
Roland Arsenault
LRRS and USCRA #763
Gino, you need to come back to your MABE/T1a roots for this race.![]()
Fuckers...next year.
R.I.P. - Reed - 3-23-2008
Come up Kurtz, We need help in the pits and you can be our Tire tech.![]()
Bill Cool --- CRA EX 47, CVMA EX 478 --- 2025 CVMA F40UL Champion, 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle / Bison
USCRA Pre-Race Tech Inspection Form
Riders: Please inspect your machines prior to tech inspection. Below is
a checklist to assist you with safety compliance for USCRA racing.
In addition, please be sure your machines are clean enough that all
of the below items can be clearly seen by the tech inspectors.
Date:_______ Rider’s name:____________________________________
Rider’s number:_______ Bike:__________________________________
Safety Wiring
_Throttle cables
_Oil lines
_Brake cable, front
_Oil galley plugs
_Brake cable or rod, rear
_Oil drain plug(s)
_Brake caliper bolts
_Oil filler cap(s)
_Brake arm bolts
_Exhaust springs
_Front fork pinch bolts
_Exhaust nuts
_Front axle, including nut
_Exhaust tail sections
_Rear axle nut, inc. bolt
_Rear brake torque arm
_Front brake torque arm
_Other______________
_ No antifreeze in radiators
_Sidestand removed
_Centerstand removed
_Kickstart pedal removed
_ Engine kill switch mounted
and connected
_ CB350 output shaft seal
retainer installed
_ Engine breather tube(s) end
secured in closed container
Tires, front and rear:
tread
depth
_rubber condition
Wheels:
_Bearing play
_Spokes (intact and
_tightened)
_Metal valve stem caps
Brakes:
_Stopping power (individually)
_Lever free play and release
_Shoes/pads wear
Chassis:
_Steering head bearings play
_Swingarm bearings/bushings
_Catch pan construction
and mounting
(min. depth of 1”;
absorbent pad in place)
Controls/Cables:
_Throttle return
_Throttle cable(s)
_No frayed wires,
operates without binding
_Brake cable, front
_Brake cable, rear
General Machine Preparation _Clutch cable
for all you cheaters out there.....
12.1 Period IV, Formula 3 classes
Period IV, Formula 3 classes will be added provisionally for 2011 season
and run concurrently with Modern 125GP.
Eligibility cut-off: Dec. 31st, 1989, no updating beyond this year.
Similar, later models without performance improvements may apply in
writing for approval.
• 125cc, 2-stroke GP
• 500cc, 2-stroke singles
• 400cc, 2-stroke street based twins and triples
(must have original frames, cylinder blocks and engine casings)
• 400cc, 4-stroke four cylinders
• 650cc, 4-stroke twins
• Unlimited, 4-stroke singles
(Exception: Suzuki GS550, Kawasaki EX250/500;
current models allowed).
Rules applicable to all Period IV, Formula 3 classes:
1. Engine: Internal modification limited only to period type.
Normal induction (no forced/ram air, except where OEM in Formula
3). Airbox and toolbox may be removed.
2. Carburetion: Any period carburetors permitted.
3. Liquid cooling: Machines must run water only and flush system
completely. Antifreeze prohibited. Water WetterŪ permitted.
4. Frame: Original or period aftermarket frame (e.g: Harris, Spondon, etc.).
Frame bracing permitted, if executed in period and workmanlike
manner. With the exception of Formula 3, Four cylinder restricted to
steel frames in period. (i.e: NO GSXR, FZR).
5. Forks/Shocks: Conventional front forks of period construction
and size. Monoshock and monoshock conversion OK.
6. Bodywork: Aftermarket permitted, period styles and materials only.
7. Brakes: Period brake systems/components only.
8. Wheels: No restrictions.
USCRA 2012 Rules Committee Meeting Summary
Proposal 1: Adopt the use of transponders for all events.
Resolution: This topic was discussed and will be tabled for the time being. There are
issues concerning costs and having to potentially employ NHMS to facilitate
electronic scoring.
Proposal 2: Race results should be posted to the official USCRA Yahoo message
board/website within (7) seven days after conclusion of event.
Resolution: Scoring for any event will be the responsibility of the Race Director(s). Race
Directors are to collect all scoring sheets and final results by the end of a race
event and should transcribe and submit those results electronically to the
Webmaster within seven (7) days of the conclusion for that event.
It should be noted that Peter Booth has assumed the role of Webmaster for
the club. In addition, Shane Rivet will help to create a spreadsheet that can
be utilized for scoring purposes. This spreadsheet will be made available to
Race Directors. Thanks guys!
Proposal 3: Please allow floating rotor for (single disk only) bikes in HWSV class.
Resolution: This proposal was not passed. No rule change will be instituted. UH Ohhhhh. no problem for our bike.
Proposal 4: Allow tire warmers in the Formula Singles class.
Proposal 5: Please allow me to run a turbo kit on my sidecar, but only me – Marcus #98
Proposal 6: Masters to be split into 250cc or less and above 250cc. The only age
requirement should be fifty and over. There would be only two classes
not four as exists now.
Resolution: Masters will now be one class and eligibility is as follows: 350cc and under/
over 350cc minimum age requirement is 50 years of age as of the date of the
event. Eligibility will remain for Period I, II, and III machines only.
Additional topics discussed and voted on:
• Regional Rep sought: With the passing of Jim Howes, a new regional rep is needed
for the Massachusetts/ East region. If any member is interest, please contact
Doug Donelan at cemoto68@yahoo.com
Do we actually have pits setup on cold pit, NASCAR-style? i.e. would an EZ-UP be useful...or do we just have to go back to the garages to swap riders, get gas, etc?
Oh, my gooodness!! God help me. So many deviants, sooo much time!
Oh, the humanity!
Stop the madness! Think of the children!
" In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
will you be shaking your head for 3 hours from the tower or will you be getting some sun with us?
