Results 51 to 75 of 117
Body Positioning Tips
  1. #51
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Re: Body Positioning Tips
    Are you on the balls of your feet? cant tell quite with those boots where your foot is but it looks like yout feet might be forward a bit, that could make getting off the side a bit less comfortable for ya..
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
  2. #52
    Feb 2009
    Lost in constant migration
    Yeah, I'm on the balls of the feet. Depending on the turn and if I feel like I have time to set up after braking sometimes I'll be a bit farther forward on them, 6 is probably as far back as they ever get because I go from braking to pitching the bike in without time between to reposition the foot. In the other turns where I'm not using the rear brake it's easier to be a bit farther forward on the foot.
    Lifer Pittenger5's Avatar
    Austin
    Wow, youre ugly.
    Zip Tie Alley #505
  4. #54
    Feb 2009
    Wow, youre ugly.
    Yes'm. That's part of the reason I hung out with you before you left, you were one of the only people there that could make me look half decent in comparison.
    Austin
    My yard was officially just stomped.
    Zip Tie Alley #505
  6. #56
    Lifer obsolete's Avatar
    Norf Sho
    BOOOOOOOM!!!! That just happened!
    -Alex
  7. #57
    Feb 2009
    Exeter NH
    Quote Originally Posted by "Dangerous" Dan K View Post
    1. That was turn 6? If so lean angle??
    2. You use the rear break? where/why?
    LRRS #951
  8. #58
    Feb 2009
    1) I think the first 3 pics are 6. I'm not 100% sure, to be honest.
    2) When I finally brake for that turn, I want to check it up as much as possible. Getting a better drive out of 3/4 than I was, using a downshift locked up my rear wheel, which I didn't like, so I toyed with a quick dab at the rear brake over the weekend coming in.
    Feb 2009
    Exeter NH
    Are you downshifting with the clutch? If so a small blip of the throttle to match yout rpm will cure that.
    If your not using the clutch to downshift i would start. Not using it can realy be a shock to the hampster that powers that beast. I heard it can knock him right off the running wheel.
    LRRS #951
  10. #60
    Feb 2009
    Quote Originally Posted by 6 Fingered Man View Post
    Yeah, I use the clutch and blip the throttle. Problem is I'm past redline once I downshift now that I'm getting a better drive out of 3/4. Rear brake didn't really work for me either, what I ended up doing was letting the engine wind down a bit while I'm on the front brake before the downshift, which works. Problem is I'm turned pretty good by then for the downshift so if I miss the throttle blip and lock the rear it could go poorly in a hurry. I figure the solution is don't fuck up the throttle blip.
    I'll have new gearing for next weekend so it doesn't matter much anymore anyway.
  11. #61
    Don't close the throttle completely when making the downshift, just that change alone will make a huge improvement in how smoothly it goes.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Yea I was going to say, that entire explanation sounds more like a gearing issue than anything else. Gearing definitely evolves as your lap times drop and you learn to carry more corner speed.
    I don't see any huge problem with your body position. You look a little tense, but otherwise in the ballpark. Just friggin ride. You will learn how to go faster using less lean angle as you go. Quick turn in and immediate throttle roll on will do it. Any hesitation to roll on will load up your suspension and have you draggin hard parts, delaying throttle application, causing more contact with the deck.
    WHACK IT WIDE OPEN. It's an EX, it ain't goin anywhere.
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Feb 2009
    Thanks guys. I'll do that then
    something witty here tsanterre's Avatar
    Milton, VT
    Any updates on this Dangerous? Did you ride this weekend?
    I did the Fishtail School a couple weeks ago (first time ever on the track), and I went this weekend and did the Penguin School / Rookie Race and got my license.
    Can't wait to get back out there! but as you can tell, among 100 other things, I need to work on body positioning as well! I think I just need to make a conscious effort to keep my head over the inside triple, I'm usually concentrating on so many other things that I kinda forget positioning and just go with what feels comfortable.
    Alot of good tips in this thread...thanks guys.
    Edit: Tried inserting images by linking to ImageShack... not working? Added them as attachments, but if somebody can edit the post so they show up in the thread go for it!
    ~that which doth not kill me can only make me stronger~
    LRRS / CCS - #103
  17. #67
    Just Registered Doc's Avatar
    Jericho, VT
    Quote Originally Posted by tsanterre View Post
    You didn't come over to say hi or anything!
  18. #68
    Milton, VT
    Doc!!
    I drove around on my Trek looking all over for you. You pitted somewhere different than the first weekend?
    I even called Russell to get your phone number, b/c apparently I had it saved wrong in my phone.
    What time did you get there on Friday?
    LRRS / CCS - #103
  19. #69
    Jericho, VT
    Doc!!
    We were pitted in the same spot. We got in about 7 or 8 on friday. I am told we drove right by your pit a bunch of times. We were using the ZX6R as a pitbike.
  20. #70
    Feb 2009
    Yeah, I rode this weekend. I crashed out of the lead in ptwin Saturday, just ran laps in GTL and won LWSM Sunday. Lots more details in my RR. I think I improved my positioning some, still some work to do but I am fairly sure I got a bit better. I definitely improved in some specific spots. I'll post up again when pics from the weekend start surfacing.
    Thanks to all that offered help in this thread, and a special help to Dan (legalspeed) for sitting down w/ me over the weekend and helping me out.
    Milton, VT
    Cool...
    I'll check out the RR
    LRRS / CCS - #103
  22. #72
    Dan...I think I beat you for worst body position...
    Feb 2009
    Exeter NH
    Love the foot position...
    LRRS #951
  24. #74
    Feb 2009
    Exeter NH
    Can i join the bad positining game?? I have the opisite issue as dan...
    LRRS #951
  25. #75
    Very simply..... eat your inside hand.
  1. Replies: 2
    Last Post: 04-13-13, 07:57 PM
  2. Body Positioning!
    By HO-HUM-R1 in forum General Bike Related
    Last Post: 03-30-12, 05:45 PM
  3. Mulholland Riders (Body positioning)
    By MonsterM636 in forum General Bike Related
    Last Post: 08-10-10, 01:56 PM
  4. I think I understand the whole body positioning thing now
    By hqp921 in forum General Bike Related
    Last Post: 02-01-10, 01:58 AM
  5. Cornering & Body Positioning break-down pic
    Last Post: 07-21-05, 12:39 PM
