Results 1 to 22 of 22
Brake line question.....
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    I notice on many factory bikes, there is one brake line coming off the master cylinder going to the right caliper, where there is a long(double) banjo bolt, bridging another line from that to the left caliper.
    Most racebikes I've seen have that long banjo bolt right on the M/C, with two seperate lines for each caliper. No bridging.
    Is there an advantage to this? I'm asking because I just upgraded to a brembo M/C and I don't have a double banjo bolt with the right thread. So I set it up like a stock bike, one line off the master to the right caliper, with a double off of that one and a line to the left. It rode around just fine at very low speeds, but I'd rather not boil all the fluid in my lines.
    THANKS!!!
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
    Lifer Wishbone's Avatar
    Jul 2006
    just did the same. brembo, ss lines and double banjo with pressure switch
    only cost 20ish bucks for the bolt with switch, so it will be cheaper with no switch included
    mabey more even pressure and better feel?
    Lifer Evil_Weasel's Avatar
    Over the Highside
    i don't imagine it will effect performance much. the main reason you see race bikes with 2 seprate lines is for saftey. if you lose pressure in one of the lines you still have the other one.
    Nov 2003
    New Milford, CT.
    If you lose pressure in one line there will be NO pressure in the other. They are not independent systems.
    The only real benefit from having 2 lines from the master is bleedability (word?) They both have a nice relative straight route to the calipers, no place for air to hide. The lines that go from one caliper to the other have to go up and over the tire, creating a nice high spot where air can get trapped.
    CCS LRRS #454
    Dec 2003
    Auburn, NH
    Quote Originally Posted by Evil_Weasel View Post
    Since they both come from the same banjo bolt, you'd lose pressure in both. I got them bled fine, I just don't want wicked fading halfway into a race.
    JT42
    myspace.com/dave_206 elwood206's Avatar
    Feb 2007
    Hampden, ME
    I noticed the same thing on my permit class instructors busa, he seemed pretty knowledgeable and said that theres no effective difference between the two set ups, just design difference. It makes sense hydraulically that there wouldnt be a difference.
    Dec 2003
    Auburn, NH
    I agree. The only thing I could think of is the brake fluid from the left caliper staying hotter, because the heat has to travel to the hot right caliper to reach the "cool" M/C.
    JT42
    shitcan it.. start over. one line to each caliper. that is all.
    Dec 2003
    Auburn, NH
    Thanks for your insight. Any reason?
    ANYONE WITH A DOUBLE BANJO BOLT THAT'LL FIT A BREMBO M/C?
    JT42
    Quote Originally Posted by Stupidhawk007 View Post
    do you see anyone else doing it?that should be reason enough. actually.. your whole L caliper being hot thing sounds like a possibility. but i stick with "do you see anyone else doing it?" theory
    Lifer smf's Avatar
    Nov 2006
    been quiet on this one, but been thinking that since you started the thread. and remember that you've been complaining about your brakes since last season. do em right . i can probably get you the banjo bolt if you run out of options, no clue what those things go for though
    Scott
    Dec 2003
    Auburn, NH
    Quote Originally Posted by smf View Post
    They're not expensive by any means, just not easy to find in the thread pitch I need. I'm gonna try to find one tomorrow, again. Thanks for the input, guys.
    JT42
    Lifer smf's Avatar
    Nov 2006
    Scott
    Jul 2006
    brembo has two different sizes they usually use, if all else fails talk to PK thats where i went for mine because i knew it would be correct the first time. and they should be under $20 because i spent about that for a double with the pressure switch
    May 2005
    Bernardston, MA
    The brake fluid doesnt actually go anywhere, does it? So the fluid sitting in one caliper usually sits right there, the fluid in another sits there, the fluid in the master cylinder is usually in that general area, and the fluid in the middle of the lines is generally in that area too. Am I not right thinking that?
    You are correct, but the HEAT goes somewhere. By conduction it travels back up the lines.
    I don't think you're gonna see major improvements on this one anyway. I'm guessing the calipers are the weak link here. Also, on a bike that old, the mounting tab on the fork is likely tweaked, reducing brake performance. Until that caliper is actually working it's best, you won't see the kind of improvement you're looking for. What was the original symptom you want to improve anyway?
    Senior Member LiononaLeash's Avatar
    Oct 2005
    Two independent steel braided lines gives more cooling surface area to cool the brake fluid. That's about the only thing I can think of for performance difference. Bleeding is easier I would think too, as others have kinda mentioned.
    May 2005
    Bernardston, MA
    Yeah, what size are those calipers? 4 pot? Cant you get away with running a beefier set of calipers if you just upgraded your M/C?
    Ok, heat conduction makes sense, I just got the sense from him that it was literally a matter of fluid travel, not heat.
    Dec 2003
    Auburn, NH
    Nonono, it was heat dissipation I was thinking about. Paul, the only problem I had was that the factory cbr f2 M/C was pretty spongy, even after extensive bleeding. Not just that, but this nice brembo unit was given to me(read:FREE). The calipers are........damn, I forget. They're stock f2 calipers. I just purchased new HH pads and new rotors also. The M/C bled fine and the lever is rock solid now. Never felt better.
    Thanks Scott! I bid on the banjo bolt. If I win, I'll change it. If not, then I won't.
    JT42
    Soundz good!
    Dec 2003
    Ma
    Are you using stock lines? A pair of braided lines would probably make more of a difference than everything else in your system.
    Dec 2003
    Auburn, NH
    No, it's got braided lines. There isn't really a weak link, except for me. I just had this trick new M/C.
    JT42
  1. SS Brake Line install
    By Garandman in forum Bike Maintenance
    Last Post: 09-10-18, 01:53 PM
  2. Brake Line Setups
    Last Post: 05-19-15, 04:10 PM
  3. Galfer brake line parts
    By Dip Dungles in forum Bike Maintenance
    Last Post: 01-04-13, 10:23 AM
  4. brake line install
    By ri-gixxer in forum Bike Maintenance
    Last Post: 03-26-07, 03:04 PM
  5. SS Rear Brake Line... is it worth it?
    By LuvDog in forum General Bike Related
    Last Post: 10-27-05, 10:47 AM
