Bought the Spiegler kit for GSXR. Rear was straightforward. But the hardware kit included a dowel and a two piece fixture. Have no clue what they are for.
What is that dang deal?
The dowel is to stick thru the banjo fitting. The other two black pieces are put together around the lower half of the banjo fitting. You use a pair of pliers to squeeze the two square black pieces together to hold the lower part of the banjo fitting. You then use the dowel to twist/spin the banjo to the proper angle needed to fit your application. Sometimes they do not come perfectly angled from the factory and need a little adjustment.
Thanks!
