Huh?Originally posted by Degsy
Did some work this weekend.
Spencer (DaSpence) came over and helped me revalve the forks and put the front end back together.![]()
What Jay you dont remember me?![]()
I remember ya, unfortunitely...Originally posted by DaSpence
Just I coulda sworn we just did those a coupla weeks ago...![]()
Um well when we took them apart there was a bad shim in the shim stack, and something else i cant remember something being in the wrong order?![]()
Well, my FIM World Supersport electrics kit arrived the other day. It came with the manual that tells you how to build an AMA or World spec CBR600F4i racer. The wiring loom is about 1/3 the size of the original and installs backwards (ECU need to be installed in the nose cone of the bike now). I need to manufacture an ECU bracket and a battery box. The ignition switch is no longer needed as the new HRC start/off switch on the right handle bar handles that function.
I also have a cable hanging down by the left side of the radiator which is where I plug in the laptop computer to program the ECU (programmable ECU in the FIM kit, no need for a power commander)
Mark, I have the instructions for using the HRC ECU program and tuning this bike. I will photocopy them and mail them to you so you have a heads-up on what will be needed. I am trying to borrow the very expensive HRC dynamic control module which lets you tune eveything in-flight during a dyno run, then download a snapshot to the laptop and ECU at the same time. It costs beaucoup bucks and I will probably have to lay down a $5g deposit just to borrow it.
I also have my swingarm spools welded on the swingarm now and they look real trick. I decided not to paint them mat black as they look more "factory" in plain silver color.
Degsy
Tuning on the fly is the way to go....
There is another chunk of software out there that allows for that...
It just gets better every year!
Lemme know when you need my address...
I have the software, just need to get hold of the tuning box.
Degs
Degy's whats that puppy expected to pull on a dyno guesstmating?
Should be able to squeeze 105 to 110 (depending on fuel used), In stock engine trim.Originally posted by RevHappy
What makes the difference is that bike will weigh a lot less than the standard stock one. So it be going FASTER!
Yep, like Mark says, about 105-110 in stock motor form. I hope to have the bike weighing less than 330lb by the time I'm finished.
Degsy
Is anyone racing the 637cc Kawasaki? I know its not legal for supersport but how about other classes It "seems" to have an advantage right out of the box!
Ohlins shock,
I ordered one of the new ohlins shocks with the high-low speed adjusters. Retail is $1039.00 and I haggled to get it for $804.00. They called me back to say it was backordered until May 1![]()
Then they called back again today to say the revised shipping date is April 4![]()
I'm trying to build a battery box that will fit in the race subframe which is proving difficult but i'll get there eventually.
The upper fairing/guage bracket that I ordered was apparently for an F4 which is why it didn't seem to fit properlyThe company used the wrong bracket as a template. they say they have sold over 40 of them like that so they are desperately redesigning and say they will have me a replacement in the next few days. I also have to design a hanger for the ECU which now has to fit into the nosecone instead of under the seat.
I have installed the HRC ignition pulse generator which will allow me to alter ignition timing via a laptop directly to the ECU (no power commander required) Also installed the HRC wiring loom, and bought an RC51 throttle assembly which is required when using the HRC kit (doesn't have the ignition shutoff integrated with the throttle assembly.
Called Lockhart phillips yesterday and ordered.
1. set of superbike racing grips $4.00
2. Set of carbon fiber brake lines (front and rear) $95
3. Shift rod $4.00
4. Fuel cap $60
5. Drain plug $5
6. Windshield bolts $5
7. Afam 47 tooth sprocket (backordered)
8. Akrapovic ti exhaust bracket (backordered)
9. Akrapovic ti exhaust hanger (backordered)
10. Water wetter $6
Some other stuff I can't remember...
Waiting for parts, but the bike is getting there slowly. It WILL be ready for the first race weekend com hell or high water.
Shoot, i don't even have bodywork for it yet...overtime here I come.
degs
Almost forgot..
I also ordered a set of these:
http://www.underleathers.com/acatalog/
They should hopefully negate the need for the infamous "dance of death" trying to get my leathers off. I actually pulled a muscle in my shoulder trying to get my leathers off my sweaty arms last year. Vanson makes the liners stick like glue to sweaty skin for some reason.
degs
Just got another call from ema www.ema-usa.com
They are having the shock shipped DIRECT from Ohlins with the correct spring for my weight, drop shipped to my apartment. Should be here middle of next week!!!!
Yahooo!!!
Degs
heheheh can we call ya Scuba Degs when you're running round the pits in your new skivvies?Originally posted by Degsy
Almost forgot..
degs
Heh heh, me, running? You don't know me very well.
I don't run ANYWHERE. Running kills people. The seditary life is for me.
Which reminds me, I'm going to wear a heart rate monitor during a race this year just to see if I can get up to 155 during a race.
degs
Sounds like you are making great progress Degs...I can't wait to see that bad boy when it's done.
As far as a battery box...check out Beth's tupperware collection. (or is the box required to be metal ?)
I've raided Kristin's cabinets more than once (oh, that sounds naughty) in a quest for the perfect housing for one project or another...
Damn, I'm sure gonna miss that dance...NOT!!!They should hopefully negate the need for the infamous "dance of death" trying to get my leathers off.
Chris J.
I thought you were doing the chicken dance![]()
2018 Harley Road Glide
2000 Ducati 900ss
2003 Harley Softail Deuce
Gotta love a set of barely used wave rotors for $165 off ebay.
Degs
Those there are some pretty cool looking wheels!!!
Dunlop painted on 'em...SWEET!!!
You always find the bargins, Huh?
Chris J.
Nice lookin' wheels big guy. I like the "Dunlop" on the rim.
Now...what's the scoop with the baby stroller box behind the rim? Somethin' about Beth you are not telling us ?![]()
DON'T DO IT!!! I have a couple I'll GIVE ya!!!Originally posted by scootertrash
Oh, bike's lookin' good...![]()
No, that box is ready for a baby shower some FRIENDS are having, nothing to do with us.![]()
The Dunlops on the wheel is a decal. I gave Jay a set of 'emdidn't he leave them with you Gordon?
Chris, are you going to be able to make it to the track this weekend for the testing session?
Degs
You could rent Tovah out for comedy relief.DON'T DO IT!!! I have a couple I'll GIVE ya!!!
Peace Out !
2000 Ducati 900ss
