Results 1 to 23 of 23
EX 500 Buying Checklist
    Feb 2009
    Lost in constant migration
    I'm working on a list of stuff to check over on the EX before buying it. Not necessarily dealbreakers, but if nothing else negotiation points. I figure 1500 is on the high side for one of these, especially one without rain wheels or tires, so it should be sorted for that price. This is the stuff I'm thinking we should check over, any input, advice and additions appreciated.
    I read a common issue is the bike popping into false neutral from 2nd gear under hard engine breaking. Any way to check that without actually riding it and engine braking hard?
    I was also told to check the tranny for smooth shifting, easy enough.
    Figure I should carefully look over the frame, fork, welds, etc. to see if there's any substantial crash damage, like a blatantly twisted frame or fork or a broken weld.
    Make sure stock exhaust is intact, since I need it to run stock class (I think he might have said he has an extra set of pipes, which would make this less of an issue).
    Wheel bearings
    Steerer head bearings
    Tires (he says they only have 1 track day on them, but who knows)
    Check where case savers mount to frame to make sure they have not damaged the frame in a crash
    Check clipons for any cracks/signs of imminent failure
    Brake Pads & rotors
    Chain
    Sprockets
    Hell, we'll even check out the grips, not that they are much of a big deal to replace. Just trying to cover all the bases to make sure I'm getting a bike that is actually worth this $.
    Anything else I should be looking for?
    Thanks,
    Dan
    Lifer Pittenger5's Avatar
    Austin
    Re: EX 500 Buying Checklist
    FWIW, the 2nd gear false neutral isnt much of a huge deal. My bike has that problem, and it only occurs on pit out. Im never in a lower gear on the track for it to happen. And it can be fixed.
    Zip Tie Alley #505
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    You know this is Shitty Mcbikefest right?
    wheres the kid that JB welded a penny to fix a leaking case cover.....
    Feb 2009
    Good to know, thanks.
    Feb 2009
    I do. I've been using that term and laughing about it since I first heard it. Still, for the price and the lack of rain wheels I want to make sure I'm getting my $'s worth, or negotiate accordingly. Like I said, a lot of this stuff isn't dealbreaker material (although a bent frame probably would be). Just good to know what to look at before I buy it is all.
    Canterbury, NH
    Quote Originally Posted by Dan K View Post
    Just bustin your balls bud, its always a good idea to check out a bike before you buy it
    Feb 2009
    All good buddy. So that list look like a reasonable run-through of stuff to check out?
    Canterbury, NH
    Basically... just make sure the main stuff is good to go (frame, motor, forks, rims, etc) when it comes to tires, clipons, chains, bearings, etc its all stuff thats either pretty cheap to replace, or stuff that you'll probably crash and break someday anyway. Race parts are designed to be replaceable.
    Thats my thought anyway, I dont' know any of the ex specific things to look for.
    Feb 2009
    Cool, thanks.
    Meriden, Ct
    Just buy that damn thing already!
    Austin
    Zip Tie Alley #505
    Feb 2009
    I'm waiting on him to get back to me to ensure that tomorrow is a go. He said sat or sunday in an email last night, I replied I'd like to go up on sat smack-dab in the middle of the 3 hour window he gave me, no reply yet. I'll call him later on if I don't hear back, but homefully I'll have that baby tomorrow afternoon
    There really isn't that much to go wrong on an EX. As long as the motor runs well (have him start it COLD, not warm when you get there), the frame/forks don't look like swiss cheese and all the bolts are there, you are getting a good deal.
    Any other spares coming with it?
    Good spares to have:
    levers
    CDI units
    Coils
    rear brake pedal
    clip-ons
    Nov 2003
    New Milford, CT.
    But don't be alarmed if it makes all sorts of nasty rapping knocking bucking spitting sounds. That's kinda normal. It IS a lawn implement, after all.
    You could also check to make sure the rear shock/fork seals aren't leaking.
    If the thing needs anything there are enough of us here and on Ebay with CHEAP parts to easily get you going!
    I think it's not pre-mature to welcome you into the world of the weirdos who actually ride these heaps! Welcome!
    Mark Dages
    CCS LRRS #454
    Feb 2009
    levers
    CDI units
    Coils
    rear brake pedal
    clip-ons
    Good to know. I'll have to ask him to make sure it's cold when we get there. Spares are pipes, speedo, carb bowls, cables & levers, but nothing substantial, as he put it on the phone. He wasn't 100% sure what was in "the box", but "the box" goes with the bike.
    Feb 2009
    Quote Originally Posted by zx1012r View Post
    Mark Dages
    Good to hear about the easy to come by and cheap parts. Also, thanks for the welcome! Even if it's not this one (which it very well may be, I'm not going down there to kick tires) it'll be another one, and soon enough
    The frames don't crack, and really don't need to be perfectly straight either. The bike has so much flex that there's a lot of "fudge factor" when it comes to straightness. The bike I did a 1:20 on had a front wheel that was like a half inch out of line with the rear.
    If it still looks like it did in the picture, snap it up. As far as value, the amount you could save is very small. It's not always possible to find a set-up example though, which is were you would really waste money (buying a street bike or something).
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Yeah, pick it up. You can always sell it for close the amount you bought it for as well.
    Nov 2007
    Dan, I've drafted up a revised checklist for you:
    1. Do I have the money in my hand?
    2. Have I traveled to the seller's location?
    3. Do I see an EX500 race bike in the vicinity of where I am standing?
    4. Does it start?
    If the answer to these questions is "yes", your quest is finished. Buy the bike.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Firefly? Is that you???
    Boston --> San Diego
    Nov 2007
    Fill me in on this one
    LRRS/CCS #103
    Feb 2009
    Quote Originally Posted by ceo and a bunch of numbers View Post
    4. Does it start?
    Just went to the bank @ lunch and got the cash, and called the due to solidify a meeting up time. Sounds like this revised list will be easy to check off.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Do a search for Username Firefly
  1. Race prep checklist
    By bostongixxer in forum Pit Area
    Last Post: 08-30-07, 06:33 PM
  2. (Possibly rainy) Day Trip Checklist?
    By Proulx06 in forum Rides & Events
    Last Post: 06-14-05, 09:39 PM
