Page 5 of 5 FirstFirst 12345
Results 101 to 123 of 123
GP Shift
  1. #101
    Re: GP Shift
    Quote Originally Posted by rolker View Post
    Let me sit your ass on a 125 for a few sessions. You won't think shifting an SV is such a chore after that.
    Just think, if your 125 adopted 1990s two stroke tech advancements you could have a usable power band wider than a Canadian nickel.
    go faster cdovego's Avatar
    Weymouth
    Re: GP Shift
    Coolest fucking feeling ever is feeling the rear slide on the exit of 6 through 7 under power.
    That and the step out from 3-4 is good times, dunno which is better.
    Central Mass Powersports #123
  3. #103
    Nov 2007
    Re: GP Shift
    The 6-7 one is much less likely to highside you than the 3-4 one... so I'll take 6-7 all day long LOL
    Or maybe the risk is the thrill
    edit: lots of movement on my r6 up 4... not so much on the SV anymore. then again i'm still figuring it out.
    Zip-Tie Alley Racing
    LRRS/CCS #103
  4. #104
    Re: GP Shift
    I've never really slipped 3-4.
    Except when I high sided the shit out of myself as a novice on my ex500 when my pipe picked the rear up off the ground.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: GP Shift
    Must have been an impressive lean or it's got a low-hanging pipe?
  6. #106
    Re: GP Shift
    I've had the SV step out in 3-4 in the dry. I chalk it up to bad bp combined with a poorly setup bike.
    Re: GP Shift
    Ex500 stock pipes hang low. Had to have the stockers for the production class. They would routinely be bent to avoid this. It was always questionable if that went above the rules.
    Re: GP Shift
    The trick was to cut the crossover pipe an inch or so shorter to pull the pipes in tighter. And then flatten the bend that sticks out by repeatedly banging it down in the corners. Then you could start dragging the case protectors. Good times!
    Re: GP Shift
    And lose your brake pads when they got low!
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: GP Shift
    And to think that sometimes I think that racing an SV is questionably smart... Lol
  11. #111
    Re: GP Shift
    It was never a question, it was absolutely against the rules as written. There was a "gentlemen's agreement" within the EX Mafia to never call another member out over it. Had I stayed in the class and wanted to push the issue I could have protested. A few big names were also doing stuff like skipping head gaskets (just using chem bond) to bump the compression a touch, etc that was also officially out of the rules. I even went as far as making rules proposals that would ok all the stuff in the off the books agreement and get it on paper but the class died on it's own so who cares now.
    Re: GP Shift
    No BASE gaskets, ok. No head gaskets? Are you sure? THe EX loves to blow a head gasket as it is. We went the other way and used cometic gaskets that were a little thicker than stock.
    Re: GP Shift
    Might have been base but I recall head for some reason. It was quite the surprise to find which is why it's stuck in my head. Sans a pesky gasket to get in the way Loctite 515/518 can do amazing things on an aluminum motor... Can also make it a PITA to take apart down the road, but when you're questing for ponies...
    Hiram, ME
    Re: GP Shift
    Fact
    Re: GP Shift
    I'll trade you even for the last round of F40 lights....
  16. #116
    Rochester, NH
    Re: GP Shift
    I've seen how you race in F40L. I'm not letting you anywhere near my 125!
    Roland Arsenault
    LRRS and USCRA #763
  17. #117
    Re: GP Shift
    What about me?
    Re: GP Shift
    New plan for October : Musical bikes, when the music stops lights go out, jump on whatever's closest and go
    Re: GP Shift
    Holy hell that would be awesome.
  20. #120
    Re: GP Shift
    I want to see Heath & co running around picking up that many rear stands...
    Jul 2014
    Central CT
    Re: GP Shift
    Do it le mans style... have someone hold the bikes at the wall, run towards it and go.
  22. #122
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Re: GP Shift
    I'll let any of you ride my bike in exchange for someone else's.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  23. #123
    Re: GP Shift
    Man, I try but she always says no!
  1. Broken Shift rod
    By ducatirdr in forum Pit Area
    Last Post: 04-17-17, 01:33 PM
  2. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  3. Where do you shift?
    By deeto in forum Pit Area
    Last Post: 10-06-08, 05:08 PM
  4. GP shift?
    By Awesome in forum Pit Area
    Last Post: 05-05-05, 05:07 PM
  5. GP Shift
    By snaggle in forum Bike Maintenance
    Last Post: 07-18-04, 12:30 AM
