Results 51 to 75 of 85
hyperpro steering damper
  1. #51
    Re: hyperpro steering damper
    Oh it's something you'll notice. I guarantee.
    Then I guess the answer is still no, I haven't felt any head shake between T7 and T8.
  3. #53
    Lifer Pittenger5's Avatar
    Austin
    I dont have one on either of my current bikes. Dont need one. Loose on the bars is good enough.
    Zip Tie Alley #505
  4. #54
    Quote Originally Posted by 07BladeRider View Post
    Try opening the throttle, That bike would shake there even with a damper. very predictable and easy but every lap.
    I have never felt the need for a damper on a motard or a Hawk. I am pretty sure I could ride that sv without one.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
  5. #55
    It will be a memorable time, Chuck, and once you get to that point you'll want a damper because you'll be hitting that transition faster and harder as your skillset progresses.
    Richie, not to take away from your post but I nearly flew into the grass when I was trying the loose on the bars method. Then again, that was on my old FZ1 which was a handful to begin with.
    By chance I owned your racebike as well And yeah that bike NEEDS a damper. My experience is any 600 or bigger needs a damper Its just a lot of freakin power.
  7. #57
    Austin
    Ride my motard, youll learn headshake and loose on the bars. Trust me. I actually kind of enjoy it.
    Remember I was shaking so bad at one point last year it was enough to push the brake pads back in the caliper.
    Zip Tie Alley #505
  8. #58
    Already learned that....then forgot for a bit until I threw a leg over Scott's 800. That bike seemed to exhibit a characteristic wallow in anything other than a straight line. Not a bad thing as it was obviously a part of that bike's personality.
    Good for hacking up teammates too!
    Austin
    Put it this way, I have a scotts damper in the garage. I havent bothered to put it on either of my bikes, havent felt the need. Granted my bikes have 108 horses combined, so it might be different than most.
    Zip Tie Alley #505
  10. #60
    I'm still sorry about that to this day.
    Austin
    Hahah, it was funny. I saw it coming so no big deal.
    Zip Tie Alley #505
  12. #62
    My spidey senses told me you were there. I thought I was clear enough to move over and then, out of the corner of my eye I see the corner of a yellow fender just as I'm cutting (no pun intended) over to avoid the upcoming greenery.
    Hey, I'm new at this!
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    Put it this way, I have a scotts damper in the garage. I havent bothered to put it on either of my bikes, havent felt the need. .
    wanna sell it??
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
  14. #64
    FWIW, I have a GPR (rotary) on my SX bike because it was cheap. It works well though and has lasted a season without failure. I was reluctant to buy it because of reports like these, but so far so good.
    I had a sprint linear damper on my racebike and it did the job as well. As long as it's rebuildable for a reasonable cost, anything will work.
    Ambition Outweighs Talent strgt's Avatar
    Jun 2009
    linear, mechanically simpler and (in my opinion) more reliable. It seems the design behind the rotary dampers makes them more susceptible to needing rebuilds (this may also just be because those dampers are made by crappy manufacturers). I know some people have had great luck with rotary. I'd be willing to try just because they take up less real estate than the linear top mount.
    Rotary dampers are manufactured with an air bubble stuck inside. Its the downfall of the design. This causes cavitation of the oil inside when heated up, and when cold will cause a skip in the stroke. Skips, and cavitation are bad in a damper. Linear dampers perform better but they dont crash as well, and take up more space. Its a trade off.
    www.streetandcomp.com
    LRRS/CCS/WERA Am. #290
    NESBA Adv. #290
  16. #66
    Austin
    Haha I saw it all unfold was like ... umm HELLLOOOO.
    Zip Tie Alley #505
  17. #67
    Austin
    Quote Originally Posted by lrrs699 View Post
    wanna sell it??
    Distinct possibility.
    Gotta make sure I can still find it first
    Zip Tie Alley #505
  18. #68
    Nov 2007
    Try going faster, you will
    Zip-Tie Alley Racing
    LRRS/CCS #103
  19. #69
    Foxboro, MA
    Quote Originally Posted by ceo and a bunch of numbers View Post
    ok oreo
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
  20. #70
    Quote Originally Posted by BLACK SQUIRREL View Post
    Yes, I realize that I don't crack the throttle WFO like I should be at times.
    But I did ended up getting a bracket on the SV for the Scotts damper that's on Annalisa's 900. I'll swap it over when I ride on the track. Takes 2 minutes and saves me $300+.
    All in good time.
  21. #71
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    wanna sell it??
    Dammitt! You beat me to it....
    I keep trying to find good comparison articles on the different brands, but havn't found a comprehensive one yet... Anyone have any direct experience with the Pit Bulls?
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
  22. #72
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by Femmekat View Post
    Stay away from Pit Bull imo. I havent used their damper but Ive also havent heard anything good about them. My experience with them is with bike that come into the shop with them mounted on. Everyone Ive seen requires you to drill into your frame to mount it. I have yet to see one Scotts damper that requires drilling to mount.
    James
  23. #73
    Nov 2007
    I don't see how drilling versus non-drilling has anything to do with performance.
    That's like saying no-cut frame sliders are superior to cut ones in terms of performance and saving your bike because they don't involve cutting.
    LRRS/CCS #103
  24. #74
    Blackstone, MA
    Well you can drill into the headstock of your frame all you want. Ill stick with the bolt on type. The penalty for drilling for your sliders wrong is a few hundred dollars for a new panel from the dealer and a little time swapping it over if you do it at all. You drill the mount holes wrong for the damper not only does it not mount right but you can weaken your frame.
    James
  25. #75
    Nov 2007
    I'll have to double check exactly which two leads you are supposed to jump in that big connector but the other ones in there are not used, I filled it with silicone. YOu can see pretty clearly which two they are though based on the pictures, the other ones I bent out of the way to ensure no contact and then filled with the silicone.
    The other large-ish connector you need to put push terminals into it, that's where the switch goes.
    Connector I made:
    Good to go, the one on the right is where the switch wires to:
    Here's the switch:
    Damper setup:
    Top view with switch good to go:
    LRRS/CCS #103
  1. Any Experience with Hyperpro Steering Damper?
    By Trajiks9 in forum General Bike Related
    Last Post: 03-31-16, 04:47 PM
  2. Steering Damper
    By Larry in forum Wanted
    Last Post: 08-23-12, 09:12 PM
  3. too good to be true? HyperPro Steering Damper, $22...
    By island boyeee in forum General Bike Related
    Last Post: 09-12-11, 02:11 PM
  4. WTB Steering Damper 03 r6
    By Jenni in forum Wanted
    Last Post: 01-22-10, 09:25 AM
  5. HYPERPRO ACTIVE CONTROL DAMPERS or SCOTTS ROTARY STEERING DAMPER
    By greco954 in forum General Bike Related
    Last Post: 06-28-04, 04:00 PM
