Results 1 to 24 of 24
LRRS Tech Inspection - Belly Pans
    Neophyte question - my apologies.
    Should I be removing my belly pan for tech inspection? This is just a belly pan, not a lower. Rules state that lowers should be removed for tech but I didn't find anything that speaks to belly pans. Just wanted to avoid taking it off if I don't need to - I don't have nice captive fasteners on there.
    Bike is a gen 1 SV650. Belly pan is DR 404 from ebay.
    Re: LRRS Tech Inspection - Belly Pans
    Belly pan comes off.
    Wirelessly posted (BlackBerry9700/5.0.0.979 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/102)
    If your oil filter is clearly visible, I wouldn't worry bout it too much. If there's any question, bring the bike over n ask. The tech guys are people too. You can ask them questions.
    I thought Tech also looked for a wired drain plug hence removing the belly...
    Yeah, was just about to add that. Was on my phone sitting in traffic when i posted.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    I've forgotten to remove it a few times, went through no problem without realizing it. But officially it should be removed AFAIK.
    Quote Originally Posted by Mad Max View Post
    I use both "U" and/ or "J" nuts similar to what's pictured in this link.
    Been using those for years and have not had an issue however I chose to reinforce the mounting points with some printed circuit board breakaways similar to the straight edges pictured in this link
    Come by North garage 10 sometime this weekend if you wanna see how it turned out.
    Nov 2007
    Raymond, NH
    Chris I've got some extra Dzus fasteners you can have if that will help, will be there Sunday only.
    Thanks for the input everyone. The safety wired bits might be visible enough with the belly pan on so I am going to leave it on and be prepared to take it off if they want to see.
    Butcher, I think I will take a look at what you've got. I don't think I am picturing the circuit board quite right.
    Brady, I might take you up on the offer for your extras. I will stick with the nuts and bolts for this round but I will make a deal with you for what you have left-over. btw, power cords for your warmers will be available if needed.
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    yeah, id leave it on, i did last round with that same belly pan. you can see the filter and drain bolt, so youre good to go. isnt that thing sweet, its super durable! (i would know, i crashed on the damn thing twice the day after i installed it )
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    Nov 2007
    Raymond, NH
    awesome, thought I was going to have to wear an extension cord necklace on the way in!
    Quote Originally Posted by darkduc7 View Post
    nice to know it's durable; any clearance issues leaned over?
    Apr 2010
    Georgia, VT
    no clearance issues that i noticed...except when the bike is sliding across the ground on its side, then it tends to touch...what a crappy design!
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    Yeah, I'm certain I didn't explain it clearly and I'm not able to post a pic since the bike is packed up.
    Basically, the straight edges on the top and bottom in the 2nd picture are the breakaways. What I did was cut smaller sections and rivet them to the mounting points on my belly pan. Had to drill a few holes but total time to install 6 of them was something like 30 minutes.
    Feel free to stop by though.
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    Glad to see someone else doing this. I can't stand 1/4 turn fasteners - I've been thinking about putting on riveted captive nuts.
    ~Scott
    2020 SMC-R
    If he doesn't have what need, I have different size Dzus fasteners. I'm in center garage 15 with the ECK team.
    Uxbridge, MA
    Put the phone down Be-yatch! :
    Went through tech without issue. Brett is right that you can see the filter and drain plug with the pan mounted.
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Heard that hawks and ex500's and tards need to have them for next round. Is that true?
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
    Member STREET&COMP's Avatar
    May 2010
    Troy, New York
    Quote Originally Posted by 6 Fingered Man View Post
    Engine diapers?
    Lifer Trouble's Avatar
    Monkton, VT
    If so they'd better let us know soon. 11 days before practice and I've never heard anything about it. That'd be kind of shitty to do with so little notice.
    LRRS EX #7
    Low Down Racing
    Rocky Hill, CT
    just FYI when I went through tech on Sunday without my lower, they made me come back with it. Apparently now they are requiring all belly pans to be inspected to ensure they will hold oil.
    I asked at tech if I should just leave the lower on as long as they could see the wired oil filter (easy on SV) and they said yes.
    So, next round I am keeping the bike together and we will see what happens. Worst case scenario it is only a few dzus to remove.
    Feb 2009
    Exeter NH
    Quote Originally Posted by Trouble View Post
    Tech told Drew he needed a belly pan for next weekend when he went through.
    LRRS #951
    Nov 2007
    Raymond, NH
    Quote Originally Posted by PainfullySlow View Post
    Makes sense, I wondered about that after my first time through tech.
    They never said anything to me about needing anything for next round.
  1. LRRS tech inspection question
    By butcher bergs in forum Pit Area
    Last Post: 06-11-16, 02:17 PM
  2. Sumo belly pans + MX stands
    By Kurlon in forum Pit Area
    Last Post: 04-10-15, 05:00 PM
  3. Belly Pans
    Last Post: 06-09-08, 09:03 AM
  4. Belly Pans... outrageous prices!!!
    By Bandit12k in forum General Bike Related
    Last Post: 09-21-07, 11:31 AM
