Results 1 to 18 of 18
Safety wiring engine "plugs"??
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    How do I go about securing these plugs for racing? Do these absolutely have to be safety wired, or may I just use silicone on them?
    Lifer 03Worc9R's Avatar
    Worcester, MA
    Re: Safety wiring engine "plugs"??
    I see these siliconed on everyones bikes.
    Mine are drilled. Drill it on an angle on the flat top toward the allen hole and wire.
    Senior Member Slowpoke387's Avatar
    Enfield, CT
    Pretty sure on both of my bikes these are not wired or siliconed. I dont believe it's required. I could be wrong though. I should prob go look, lol.
    LRRS #387
    Not needed
    No need to do anything with them but if you're not comfortable with that, dab 'em with some hi-temp RTV
    i was gonna say, but already some of the people who commented cover me, that seems really unnecessary to me.
    mine arent done either. nor are my header bolts.
    what NEEDS to be done are:
    Fork pinch bolts
    front axle
    caliper bolts
    coolant drain
    radiator cap
    oil fill
    oil drain
    oil filter
    rear axle
    the bolt that connects the muffler to the hanger
    rear caliper (mines not but never been hassled)
    i think that just about covers the MUST DOs
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Fork pinch bolts
    front axle
    caliper bolts
    coolant drain
    radiator cap
    oil fill
    oil drain
    oil filter
    rear axle
    my rear caliper isn't done either and nothings been said to me about it in tech.
    headers are required to be wired. on an inline 4 just the 2 outside ones need to be done. However mine aren't and I haven't even seen them look at it.
    Just Registered Doc's Avatar
    Jericho, VT
    Great time to get it done...
    What if someday they do look?
    i personally dont get the header thing. where are they gonna go? into the belly pan?
    rear caliper, while i can see why it should be done, seems a bit excessive. whens the last time you removed a rear caliper? the front ones get done all the time to remove the wheel so that increases the chances of them not being torqued properly. my bike is 11 years old (holy shit my bike is 11 years old!!!) and the rear caliper has NEVER been unbolted.
    Bridgewater, MA
    yup. I plan on doing them once it gets a bit warmer out.
    I think I unbolted the one on my 929 (its also 11 years old) once when changing the pads. But it was more to be able to clean it better.
    Dublin, NH
    I unbolt my rear caliper every time I take the rear wheel off.
    2023 KTM 890 Adventure R
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Fork pinch bolts
    front axle
    caliper bolts
    coolant drain
    radiator cap
    oil fill
    oil drain
    oil filter
    rear axle
    You mean the Axle pinch bolts and not the triple clamp pinch bolts correct??
    Uxbridge, MA
    Yes Sir
    Derry NH
    I'm with this guy. My rear wheel won't come off without taking the caliper/bracket off.
    Enfield, CT
    I got bounced outta there last yr for no rear caliper wiring. Couldn't believe it, been running it that way for 3 yrs before that.
    LRRS #387
    Quote Originally Posted by Eric Baker View Post
    weird
  1. From "Sunuvabitch" to "Hell yes" to "WOOT!"
    Last Post: 05-16-12, 06:46 PM
  2. Wiring "audi" lights on an F4i
    By Kazinator in forum Bike Maintenance
    Last Post: 08-03-11, 08:01 AM
  3. Motorcycle "safety" checkpoint in Sterling
    By JohnnyV in forum General Bike Related
    Last Post: 08-14-09, 11:31 AM
