hey. i'm here at doc's finishing up his racehawk and i can't remember... do you have to wire the bolts holding the water pump housing? (mine are done, but that could be b/c i'm neurotic about these things)
thanks![]()
Scott
if its a drain then i would do it. my drainbolt is but not the rest
A good rule of thumb is that if a bolt backing off causes fluid to leak, wire it.
Johnny B. (the other one) ®
thanks guys, drainbolt drilled and wired
Scott
