Just generally, a little confused confused, because sometimes the rulebook takes a "must not modify abc" and sometimes it takes a "can modify abc" so I don't know if it's silent on an issue if that means you're allowed to modify it or if it means it's off limits.
More specifically:
I'm upgrading my suspension (rear shock and cartridges).
I'm unclear on whether that disqualifies me from the Supersport classes....
Not sure I even care but want to get this trackintel interview right so it's reasonably reliable in the future
Maybe I'm wrong, but I think of the classes generally as a spectrum from production > supersport > superbike > ... > .... > GP/GT
...or is it more hierarchical that the "production" classes ARE supersport, superbike, etc....
So the rulebook says "production" class rear shock may be replaced as long as it mounts in the same place (20.1.1.5), no mention of forks except that stops may be added.
The "supersport" class makes no mention of rear shock replacement (that I can tell)...but if you can replace it in the "production" class, you can replace it in the "supersport" class, right?
Supersport does say that forks must be stock, but does that mean you can't so anything with the internals? (either cartridges or adding emulators)
I doubt I'll be setting the world on fire, just trying to be on the up and up....
LRRS 919
Well...forget trusting the interview...I clicked into the other bikes and it seems to be a jumble of the two different bikes....
I'm pretty sure when I filled this out, I didn't say my KTM 520 was a 600cc i4...
Or that my GSXR 600 was a 2 cylinder bike.
I'm not above making mistakes but every time I change the answer on one of the bikes the whole thing jumbles up even worse... :dunno
Somebody that works in IT go ahead and tell me to "clear your cache, delete your cookies".
Me and technology are not getting along today....
LRRS 919
SS - You can replace the rear shock, but you have to use the OEM suspension mounting points. On the forks, you have to retain the outer tubes, you're free to replace the internals though.
LRRS 919
