Hi Guys,
I am considering purchasing a set of motard wheels for the YZ. The set I am looking at is a 17x3.5 front and a 17x5.5 rear. The front is very common. The rear seems to be very wide. The guys says that these fit an 06 YZ450F with out rubbing using a 520 non oring. My gut is saying that I should stay away from these because the rear will be too wide. What tire would I run on this anyway, 180? That seems too wide. What do you guys think?
Thanks for the advice in advance.
Nathan
search this topic on supermoto junkie .... or ask there you will get a wealth of info... seems wide as most 160 tires show signs of rubbing
Where in NH are you?
2001 RC51!!!
2007 Husky SMR 510 - no longer... blown tranny
You're not going to just bolt that one on and not have to worry about anything. I have a 5" rear on my YZ, 160 tire and a 520 non O-ring chain and I had to space the sprockets 1/16", use a Graves chain block and even had to shave a bit of the tire with a block plain. I have less than 1/16" clearance between the tire and chain.
Also, I don't even see you getting that in the swingarm without a major pain in the balls. The 5" with a 160 is a pain as it is.
While I think it would look killer on the YZ, I'd stay away from that sized rim![]()
I have already asked at SMJ. I am just trying to get a few different opinions.
I am in Nashua.
Thanks,
Nathan
I don't know the bike specifically, but I did a bunch of searches on sizes for rims when I bought new ones and the general consensus was 5.5 too big.
EVERYTHING is a repost
06 749R #0047
08 R 1200 GSA
13 Monster EVO 1100
There's no way it's going to fit in a stock swingarm. I'm maxxed out with the set up I have as far as room. I also forgot to mention that when my wheel was laced up, it was set up offset from center to reduce the chain rubbing issues.
This picture may give you an idea just how close it is?
I don't know how people do it, I have a 5.0 on my crf as well and don't see how I'd go bigger really. I almost bought a crf already in supermoto form that had a 5.5 rear but I never got to see it in person before it drown to death.
LRRS #399
MX #505
yeah, I'm with stupids. Can't see anything beyond a 160 fitting on a typical motard. Some 160's (Power Race for example) won't fit without a fair amount of coercion. I wouldn't really be too stoked about putting a 160 on a 5.5" rim... Seems like you're already leaning towards passing on the deal. I would.
Both Mark R7 and Seth would find out that "most" Tire company slicks Run a Little narrower then DOT's. a 160 slick would fit better then the Dots they are running. Street tires (corsa III, Pilot powers ect) alway Run the widest. That being said I dont see any benifit to a 5.5 Rear that would still be a Pain to deal with.
Zip Tie Alley Racing #444
Signature edit by Tricky mike
Why you splitting hairs Dolla Bill?
KR108's are quite a bit narrower (at a listed 165 width) than a Power Race (at a listed 160 width). As the squirrell of darkness points out must slicks are narrower than their DOT counterparts. I'm just trying to keep things simple. I'll stab you.![]()
When Seth Had His Diablo DOTS mounted at Tricky Mikes we measured the Mounted DOT VS the Dunlop 165 Also Mounted And the Diablo was MUCH Wider
** Gets shiv From Tricky Mike and Wipes the Blood Off**
So, it sounds like I should stay away from the 5.5 inch rear. That is what I thought. Kirk from factory pro says that a 5.5 rear will fit. I am not conviced yet.
I do currently have a set or tard wheels and the rear is a 17X4.25. I guess I will just stick with these for the time being unless anybody can change my mind.
Thanks for the help guys.
Nathan
Yeah, I'd pass, personally...
It might fit, but I don't really see the point. It's not so much whether a 5.5 would fit, it's that a 180 tire has no chance of fitting, and isn't needed for a bike putting out motard HP... and mounting a 160 on a 5.5 would result in a flatter profile that the manufacturer hadn't intended. The net result would be that for the additional unsprung mass due to the wider rim and hassle trying to squeeze it into the swingarm you get no reward. Unless, of course there's a legit reason for running the 5.5 and flattening out the profile of the rear tire. I dunnoIs this one of those fast guy mods?
Any chance the tilres buldge will be decreased by squeesing the 160 on a 5.5 and give yo a little more clearance. Come to think of it. I have seen Alexs rear rim (not a 5.5) and it is all beaten up from the chain. Going wider is going to create more of a problem.
Degsy mentioned to me that he put a 160 slick on my 600 rr and it was flicken machine. I'don't know if I want to do that.![]()
5.5" wide rim on motard = FAIL
Boston --> San Diego
hot damn
LRRS #399
MX #505
Yes I have 5" rear wheel on my RMZ.
250's = 4.25
450's = 5
