Results 1 to 13 of 13
Who wants to bleed my brakes?
    Mar 2004
    woonsocket ri
    So I finally registered my bike and decided to take it for a ride. I got out onto the main road and when I got to the lights my brake went away. I have been trying to bleed them and I can't get a drop of brake fluid to come out. I had to stop because I want to kick the fucking thing over then beat the neighbors cat.
    I bled them a couple months ago with now with no problem. Today I get nothing. No pressure, no fluid and no patience.
    Banned G21forme's Avatar
    Lakes
    Re: Who wants to bleed my brakes?
    Get one of those brake bleeding pumps.
    eta
    Or ride to boston w/ a bottle of dot 4 and I'll do it for you
    Raymond NH
    Brakes don't go from being correctly bled to suddenly needing a good bleeding. I'm guessing something else went wrong. Can you pump them up and get a firm lever? Any idea why they suddenly went away? Were they fine then "nothing"?
    Mar 2004
    woonsocket ri
    They felt fine when I left my house. I stopped once, then the second time they werent there. I had rear brakes and I rode it back to my house. I cant pump them up at all.
    Raymond NH
    Sounds like a failed master cylinder or caliper. My guess would be MC. What year and model bike?
    I second the failed master cylinder.
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Just curious, did you check the brake fluid level. If there is fluid then I`m with stoinky and bergs on this one.
    Mar 2004
    woonsocket ri
    It's a 2003 SV650S Yeah I checked the fluid.
    Raymond NH
    Should be easy to find a rebuild kit or an entire MC; that's a really common bike and it uses an MC found on tons of other bikes.
    Any leakage at the calipers? Did a pad happen to fall out? If there's no obvious reason for the problem, buy and install a new MC, or rebuild yours.
    May 2007
    Southern NH
    If either the master or calipers failed, wouldn't the fluid be leaking? Or, to ask another way, is it possible for a hydrolic failure without a leak? Can't picture it...
    Oh, wait...yes I can. If it's the Master Cylinder and the piston 'o rings?' fail then the brake fluid wouldnt be pushed to the calipers...but there would be no leak! Right?
    Muhammad Ali.
    Raymond NH
    If the calipers fail, you'd see a leak. If the master fails, it leaks, but it leaks into the fluid reservoir.
    Savannah, GA
    try cracking the actual banjo bolts to see if you can get some fluid flowing...
    If not, good chance of the failed master.
    The best advice I’ve ever been given is to not forget where you came from.
    Mar 2004
    woonsocket ri
    I'm just going to bring it to the shop. I'm not really in the mood for fixing it right now. That and I'm being lazy.
  1. brake bleed question
    By backinthesaddle in forum Bike Maintenance
    Last Post: 11-14-21, 03:05 PM
  2. Soft brakes after bleed
    By AVI8_636 in forum Bike Maintenance
    Last Post: 07-17-14, 08:16 AM
  3. Bleed coolant..
    By cdseven95 in forum General Bike Related
    Last Post: 07-06-10, 07:18 PM
  4. Only Ninjas bleed?
    By Ericthejet in forum Bike Maintenance
    Last Post: 04-01-10, 09:30 AM
  5. air in your brake lines? DON'T bleed them!
    By LiononaLeash in forum Bike Maintenance
    Last Post: 07-15-06, 08:39 PM
