Results 1 to 11 of 11
Blue S#$% on + battery terminal
    My truck battery generates a lt of blue flaky acidy stuff on the positive terminal. If I clean it, grease it with dielectric, it comes back very quickly. What does this mean? Battery holds a charge very well.
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Blue S#$% on + battery terminal
    The 1-2 punch
    clean then protect
    Dublin, NH
    Corrosion. Is your truck stored in a moist wet area? Normally the terminals getting a bit of condensation on them is what causes the hydrogen released from the battery to start corroding the terminals. Best thing you can do is clean it off, smear battery terminal dielectric grease all over the terminal and make sure everything under the hood is dry.
    2023 KTM 890 Adventure R
    Vaseline.
    Lifer Falko's Avatar
    MoonTown
    Clean it with baking soda to neutralize the acid. then coat with grease. Once the corrosion is established, it is difficult to get rid of.
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Coca cola works too, to clean off the corrosion.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Clean the entire top of the battery not just the terminal
    Large member Larry's Avatar
    Nov 2010
    Limington maine
    Add an corrosion inhibiting felt washer after you clean it. Cheap $ at any auto parts place or Wally World. They don't prevent corrosion, just slow it to a manageable rate.
    Meriden, Ct
    I've never had this issue with any of my vehicles (lie).
    I attribute that to being of average height.
    While you are under the hood check all your grounds.
    If the cables are of different metals (ie copper or brass plated) this tends to happen frequently. Also if the alternater output is high (voltage regulator) and the battery is then putting out excess fumes then this would cause frequent excess buildup of corrosion. Also a battery at the end of its life cycle tends to put out additional fumes.
  1. Broken battery terminal connector
    By MattR302 in forum Bike Maintenance
    Last Post: 03-24-22, 10:22 AM
  2. Replies: 2
    Last Post: 08-07-19, 01:30 PM
  3. Replies: 20
    Last Post: 05-22-19, 07:28 PM
  4. Battery Tender / Deltran lithium iron battery
    Last Post: 03-16-15, 06:00 AM
  5. Blue Cross/Blue Shield and racing
    By CMG241 in forum Pit Area
    Last Post: 02-24-08, 07:02 PM
