Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Brake Bleeding/Bleeding Alternative Help?
    Re: Brake Bleeding/Bleeding Alternative Help?
    Quote Originally Posted by akira700 View Post
    You know if all this don't work you could have a leak at the threads in your bleeder screw.
    If you have a bleeder that's leaking by the threads even when seated, you need a new bleeder screw. The screw seals at the seat, not the threads. Ideally the bleeder is softer material than the caliper body, so if someone JAMMED it in there in the past, the conical tip of the bleeder is what deformed and not the caliper itself. Brake fluid will do mean things to teflon tape, so at best you've only delayed a repair by trying to fix the problem that way.
    I Dance With Will
    Oct 2002
    unknown
    1. open the top of the reservoir.
    2. pour in fluid to the top
    3. Attach tubing to the bleed nipple.
    4. loosen the bleed screw
    5. slowly close the brake lever
    6. tighten the bleed screw
    7. slowly release the brake lever
    repeat 4 thru 7 as many times as needed to get fluid to start coming out.
    d
    i can see now that this would work. i missed a ride last week because i changed breaklines and couldn't get the fluid to flow. felt stupid. ended up buying the pump for $30. made things much easier. only take few minutes.
    "fuckit!"
    Lifer obsolete's Avatar
    Norf Sho
    If a vacuum bleeder doesn't work then I would guess you either have air getting in somewhere or there's a bubble in the master.
    -Alex
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    All good but I often only get solid brakes by bleeding the bango same as
    bleeder screw
    crack while slowly pulling lever and if you can shut off before lever bottoms
    rinse and repeat...joke do it till you don't see bubles plus 1... also sometimes after 1 week when use has got the air moving up in the system
    Glen Beck is John the Baptist
    Quote Originally Posted by richw View Post
    bleeder screw
    Rich has a good point. If the reservoir end banjo is uphill from the reservoir, you can crack the banjo for a split second with a cloth wrapped around it. I have had to do that once or twice also.
    derek
  1. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  2. Brake Bleeding
    By Slyder in forum Bike Maintenance
    Last Post: 05-22-08, 02:13 PM
  3. brake bleeding??
    By FireFly in forum Bike Maintenance
    Last Post: 06-20-06, 05:16 PM
  4. Brake Bleeding problem...
    By Hamburgler in forum Bike Maintenance
    Last Post: 05-16-06, 08:01 AM
  5. Bleeding Brake lines
    By RevHappy in forum General Bike Related
    Last Post: 06-28-02, 06:57 AM
