Results 1 to 18 of 18
Breaking my chain...
    Feb 2008
    Rhody
    In the process of parting out my bike I've sold the chain, is there a way to break the master without using a chain rivet tool? Should I sawzall the thing? If not, does anyone in RI have a tool I could borrow?
    TIA
    Matt
    Hyper
    Lancaster
    Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 5_0_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9A405 Safari/7534.48.3)
    U can cut the master with a cutoff wheel, just be careful not to hit other links with it.
    Corey
    Re: Breaking my chain...
    You are welcome to use my tool.
    Feb 2008
    Rhody
    Makes sense.
    Thanks for the offer, I'm going to try and find something a little more local, that's a long haul to Pomfret for us Rhode Islanders... But if I can't come up with something around here I'll be in touch.
    Matt
    Hyper
    Westford, MA
    Bolt cutters.
    ...I have your pants!!!
    I usually just grind the heads of the rivets off the rivet master with a dremel. Takes all of 5 minutes.
    KB KB's Avatar
    Manchester NH
    We know you don't use it. Might as well let someone use it.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Are you re-using the rest of the chain?
    If not, cut it wherever you want with whatever you've got
    If so, it'll take a chain tool or some creativity.
    EDIT: Durrr, reading comprehension fail.
    Assuming the buyer has a chain tool (which they'll need to install it), just slice n dice.
    If you are parting the bike out why not just take off the swingarm and front sprocket and leave the chain whole?
    Lancaster
    Quote Originally Posted by csmutty
    Chain goes through the swing arm....
    Corey
    who knows
    ^^ what he said. beat me to it. I mean assuming he's parting out his RC51
    Dublin, NH
    I tried using a chain tool on my TLS chain and it stripped the threads off the tool.
    I assume you have a rivet style chain? If so, I'd highly recommend a grinder.
    2023 KTM 890 Adventure R
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    I believe the thread title was break my "chain", not Cherry.
    Feb 2008
    Rhody
    Hyper
    Lancaster
    Quote Originally Posted by SRTie4k
    Your supposed to grind the rivets smooth and then use the tool
    Corey
    I have never ground the rivets before using the tool. Even when using the crappy harbor freight/cycle gear one.
    And good call on the swingarm. I'm use to dirt bikes.
    Lancaster
    I have the rk chain tool and the harbor freight one. Harbor freight one is great for breaking but sucks for riveting and vise versa with the rk, first chain I broke I snapped the pin.
    Corey
    Weird...I have the same exact ones.
  1. What chain-breaking tools do I need?
    By number9 in forum Bike Maintenance
    Last Post: 09-09-16, 10:42 AM
  2. Breaking in leathers help
    By DynoTune in forum Pit Area
    Last Post: 07-12-11, 07:57 PM
  3. Replies: 0
    Last Post: 05-03-07, 12:51 PM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
