Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
Brought home a ZX7- trouble shootin help!
    Re: Brought home a ZX7- trouble shootin help!
    ohhhh, nvm...I thought pulling the plugs allowed it to spin freely
    yep, still high...50-60 hour weeks, 2 hour round trip commutes, and working 6-17 days in a row...good f'n money picking up extra shifts in healthcare, but yes, I'm usually a little brain dead while forum browsing
    Feb 2012
    Pulled the exhaust;
    Oh dear! What now?
    Too many bikes to list
    Mosdt likely drunkd
    Member yzedf's Avatar
    Feb 2006
    W Greenwich RI
    Pull the head off and see how bad the piston is. Or buy a used engine. Or just sell it to the next unsuspecting bastard.
    Feb 2012
    Lol I paid so little that I don't feel bad.
    Can the head be pulled with the engine in the bike?
    Mosdt likely drunkd
    Wirelessly posted
    Quote Originally Posted by Garrett
    Yep. Pull the head. Check it out.
    "It was running when I parked it"
    Lol.
    Feb 2012
    I'm going to pick up the title right now. He's gonna get an ear full.
    Mosdt likely drunkd
    Feb 2006
    W Greenwich RI
    What year?
    Feb 2012
    '96
    Mosdt likely drunkd
    Feb 2006
    W Greenwich RI
    Carbs off, exhaust off, cams out and unbolt head. Pull head off and make sure cam chain doesn't fall down in.
    Feb 2012
    How does one deal with the cam chain?
    Mosdt likely drunkd
    Wirelessly posted
    Drain coolant from head first.
    Feb 2006
    W Greenwich RI
    Run a small wire through it and pull it up. Once head is off tie wire to something up high like frame or triple clamps.
    Don't forget to drain coolant first.
    Wirelessly posted
    Zip tie it up to a hose or wiring loom or something.
    Oh dear! What now?
    we need to buy you a new camera!!
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Quote Originally Posted by yzedf View Post
    ....and the oil!
    Raymond NH
    Pull the right side crankcase cover, there may be a cast-in guide in the engine block that prevents the cam chain from jumping teeth on the crankshaft, even if the chain is completely loose. I know my 9R has this feature. Makes it nice not to have to worry about the cam chain falling in and moving to a different spot on the crank and I can reset cam timing with Sharpie marks on the cam sprockets and chain.
    Wirelessly posted
    Quote Originally Posted by stoinkythepig
    He might have that casting. It's helps in some ways but can cause problems in others.
    Feb 2012
    Now the $64,000 question; do I replace just that valve? Assuming the piston is still good.
    Also how the fawk does that happen?
    Mosdt likely drunkd
    Wirelessly posted
    The picture sucks. I'm guessing its a bent up valve.
    There are a number of reasons, most of them involve a lot more than replacing the valve.
    You MUST pull the head no matter what, and inspect the piston. When you take the valve cover off, you might see what things went south.
    You could be into a camshaft, a head, piston, rod, rebore, who knows.
    You can probably find a motor for $500 and throw it in. I know the 900 motor fits also.
    Feb 2012
    The valve isn't bent- the head broke off and went into the combustion chamber. The only part still visible with the exhaust off is the stem
    I pulled the valve cover and everything looked fine.
    This guy has had this engine for over a year now, I could low ball him and just swap it out.
    http://providence.craigslist.org/mcy/3784276746.html
    Mosdt likely drunkd
  1. So I brought home a fat chick.....
    By JohnnyV in forum General Bike Related
    Last Post: 10-04-13, 10:44 PM
  2. You are not gonna believe what I brought home...
    By RadHawk in forum General Bike Related
    Last Post: 08-08-13, 04:00 PM
  3. Brought the DR-Z400SM home today...
    By The Wreck in forum General Bike Related
    Last Post: 07-08-05, 07:30 PM
  4. WOOOHOOO! look what i brought home today!
    By chr|s sedition in forum General Bike Related
    Last Post: 01-21-05, 12:16 PM
