Results 1 to 3 of 3
SS Brake Line install
    Bought the Spiegler kit for GSXR. Rear was straightforward. But the hardware kit included a dowel and a two piece fixture. Have no clue what they are for.
    What is that dang deal?
    Oct 2012
    CT
    Re: SS Brake Line install
    The dowel is to stick thru the banjo fitting. The other two black pieces are put together around the lower half of the banjo fitting. You use a pair of pliers to squeeze the two square black pieces together to hold the lower part of the banjo fitting. You then use the dowel to twist/spin the banjo to the proper angle needed to fit your application. Sometimes they do not come perfectly angled from the factory and need a little adjustment.
    Thanks!
  1. Brake Line Setups
    Last Post: 05-19-15, 04:10 PM
  2. Galfer brake line parts
    By Dip Dungles in forum Bike Maintenance
    Last Post: 01-04-13, 10:23 AM
  3. Brake line question.....
    By 13 in forum Pit Area
    Last Post: 04-12-07, 04:57 PM
  4. brake line install
    By ri-gixxer in forum Bike Maintenance
    Last Post: 03-26-07, 03:04 PM
  5. Who wants to help me install SS brake lines?
    By jwm2k3 in forum General Bike Related
    Last Post: 05-19-06, 06:14 PM
