2006 gsxr 600
I thought I could breez through this but not so much.
Im relpacing the worn out stock tenstioner with a manual one.
ok, so im cranking over the engine the right way but Im having a hard time feeling if, or when the adjuster is making contact with the glide ect.
Im suposed to feel it contact then back out 1/4 turn then tighten down. But I dont know if I have it to tight or loose against the slide/glide cause its hard to feel.
any tips.![]()
Perhaps a spot of oil on the adjuster's threads may help you feel "contact" with the timing chain guide?
I think Degsy holds the record for fastest CCT swap on an F4i....
If you can't Race it or take it to bed, it's not worth having..
if you can get all the slack on the tensioner side of the chain (this will only be possible at certain parts of the 720 degree rotation window) AND if you can turn the adjuster by hand (or with a very short wrench to minimize your leverage) you should be able to tell when it make contact by it suddenly getting harder to turn.
Get out while you can
Find your own path
if possible talk to degsy he installed mine on my 675
2006 Red Triumph Daytona 675
