Results 1 to 13 of 13
Clutch lever vertical play
    Senior Member AEG's Avatar
    Aug 2012
    Simsbury, CT
    I replaced the OEM levers with the aftermarket levers and white the break lever sits perfectly the clutch lever has a bit more than I'd like of a vertical play. I'm thinking to slot a thin washer to tight it up somewhat but thinking to avoid any resistance it might cause. Any suggestion on the material - nylon, copper? Will it matter? Thx
    High maintenance priss
    Central MA
    Re: Clutch lever vertical play
    Can you squeeze the perch with a clamp a bit (while lever is removed) to take up the play? If bike was in a tip-over it could have spread the perch a bit.
    Same thing happens with knock off leavers......washer it
    Aug 2012
    Simsbury, CT
    Nope. The bike was never on its side.
    Yep, the Chinese levers that look like a very good quality product.
    Does it matter what material the washer is made off? To avoid any additional friction.
    The flop doesn't really bother me...... but it did on the wifes Grom. I ended up using some plastic ones from an old wind screen.. just a little lube also helps get the pin in
    Central MA
    I'd think anything that doesn't swell or gall would be fine. Clutch levers are typically anodized AL, sometimes w/ a bushing right? An oilite bronze would be nice but doubt you'll find something thinner than 1/16". So I'd say teflon or nylon since you can get them in pretty thin versions. And don't go nuts trying to get all the play out.
    Aug 2012
    Simsbury, CT
    Thanks guys Clutch lever vertical play
    did you remember to switch over the brass bushing if needed?
    Aug 2012
    Simsbury, CT
    Yes, I relocated the bushing from the OEM lever to the new one. The play is actually not that bad, I might be just too anal about it.
    New Haven-ish, CT
    Use an exacto knife to cut a couple little washers out of an old milk jug.
    This also works to make low-friction washers between grips and the throttle housing.
    that happened to me on my sv650, I discovered the whole clutch perch assembly was relatively inexpensive ($30±) so I just replaced the whole shebang
    why fuss?
    let this thread be a reminder that lubing the pivots on your leavers is part of routine maintenance
    Aug 2009
    Drill a hole in a correct thickness guitar pick and your bike will rock!
    Aug 2012
    Simsbury, CT
    Randy, the clutch perch is a few months old and in great health. Why replace. The lever might be just a bit thinner than the OEM.
    Steve,
    I tried to learn how to play guitar as a teenager. I am a tone deaf like a doorknob. Would not know where to buy one.
  1. No clutch lever? No shift lever? No footpeg? No problem.
    Last Post: 08-29-11, 01:25 PM
  2. anyone have a clutch lever
    By Truth in forum For Sale
    Last Post: 10-20-08, 08:12 AM
  3. Front brake lever play, air in the line?
    By Cheese in forum Bike Maintenance
    Last Post: 06-25-08, 03:49 PM
  4. Clutch lever?
    By Honclfibr in forum General Bike Related
    Last Post: 04-08-05, 07:33 AM
  5. Clutch Lever
    By Cowboyrider in forum Bike Maintenance
    Last Post: 09-01-03, 09:31 PM
