I replaced the OEM levers with the aftermarket levers and white the break lever sits perfectly the clutch lever has a bit more than I'd like of a vertical play. I'm thinking to slot a thin washer to tight it up somewhat but thinking to avoid any resistance it might cause. Any suggestion on the material - nylon, copper? Will it matter? Thx
Can you squeeze the perch with a clamp a bit (while lever is removed) to take up the play? If bike was in a tip-over it could have spread the perch a bit.
Same thing happens with knock off leavers......washer it
LRRS EX 66
factoryeffex
The flop doesn't really bother me...... but it did on the wifes Grom. I ended up using some plastic ones from an old wind screen.. just a little lube also helps get the pin in
LRRS EX 66
factoryeffex
I'd think anything that doesn't swell or gall would be fine. Clutch levers are typically anodized AL, sometimes w/ a bushing right? An oilite bronze would be nice but doubt you'll find something thinner than 1/16". So I'd say teflon or nylon since you can get them in pretty thin versions. And don't go nuts trying to get all the play out.
Thanks guys![]()
did you remember to switch over the brass bushing if needed?
Yes, I relocated the bushing from the OEM lever to the new one. The play is actually not that bad, I might be just too anal about it.
Use an exacto knife to cut a couple little washers out of an old milk jug.
This also works to make low-friction washers between grips and the throttle housing.
that happened to me on my sv650, I discovered the whole clutch perch assembly was relatively inexpensive ($30±) so I just replaced the whole shebang
why fuss?
let this thread be a reminder that lubing the pivots on your leavers is part of routine maintenance
Drill a hole in a correct thickness guitar pick and your bike will rock!
Randy, the clutch perch is a few months old and in great health. Why replace. The lever might be just a bit thinner than the OEM.
Steve,
I tried to learn how to play guitar as a teenager. I am a tone deaf like a doorknob. Would not know where to buy one.
