Going to change the coolant in my bike as its about 10 years old....only 12k miles on it but I think its time to change it.
How many quarts do I need? I thought i had read 4 somewhere, but some other posts on forums say only 3.... I trust you Nesr'ins so help me out.
'02 F4i
I just fill it up after draining.....then burp it...then fill it up again while burping.
08 CBR 1000RR street bike
99 R6 track bike
02 F4i sold to a nesr member
Changed the coolant today.... Only took 2 quarts tho. Manual said it should take close to 3. I followed the instructions in the manual... How the hell did I miss a quart in there?
I took out the drain plug and drained the overflow hose....
'02 F4i
Wirelessly posted
Pretty sure my 600rr only takes 2 usually. Did you drain the engine block and the water pump drain?
Corey
Yup. Didn't flush it with water though. Only drained the hose and bolts.....
'02 F4i
Wirelessly posted
Radiator mount bracket?
could it be a blank hole used in manufacturing and left there
or
they use the engine block in another bike and on yours it's not used (F4i and 600RR are the same engine with a few modifications ?)
or
maybe an option you don't have. do they make engine block heater for bikes? I thought I saw one for my bike before
If your bike isn't missing anything I would worry about it.
Just switched out the oem air filter for a k&n.
Any idea why the oem has 2 pieces of plastic that sort of flare up, while the k&n doesn't?
'02 F4i
Pic would help
99 R6 track bike
Still a legitimate question tho...
Wondering what the purpose of those flares on the oem are as they are pretty large.
'02 F4i
i will answer without seeing what you are talking about.....i think they are for keeping the air filter in place.
aftermarkets do not have these as they know better.
Honda engineering sometimes goes overboard.....you will know what i am talking about if you DIY Honda's...perfect
example is the brake rotors on Honda cars, they have a screw that bolts on to the hub.....the rest of the world dont do this
hence any aftermarket you get for honda rotors will not have the hole for the bolt.
99 R6 track bike
i stand by my statement then.....it is there to keep it in place.....but that is the Honda way.....over the top
99 R6 track bike
I was wondering if it aided in the direction/flow of the air within the box.....?
'02 F4i
Ride more. Worry less.
I'm going to guess that those are there to reduce the amount of intake noise because I know when I'm using all the power on mine it's effin' loud underneath that fuel tank.
FWIW; the BMC in my F4i doesn't have those either.
Those big friggin fins? They look very much like air directors. Like bergs said probably acoustic. Never owned an f4i but worked on Honda's cars with friends. They do all kinds of weird shite when it comes to intake piping etc. Just ride the thing if you notice something adverse after changing the filter deal with it then. If not don't worry about it.
Definitely not worrying about it, just curiosity.
I have ridden about 150 miles with the k&n air filter and havent noticed anything really different yet. Acoustic-wise I actually thought it has sounded a little bit quieter with the k&n.
'02 F4i
Yer gonna loose like 50HP! Best make it up with stickers or by extending your swing arm.
